Using Midi And Computer With Spider Valve Mkii 1x12
midi
12 replies to this topic
#1 lleichtman
lleichtman
  • 47 posts
  • Registered Products:3
Posted 18 December 2013 - 03:33 PM
Can the midi input be used with the eidtor program for spider valve MKII? I can get the program running with a midi connection and it recognizes the amp but when I try to send a patch nothing happens. So, is the only way to edit the amp from the front face because this is really tedious and you can't download anyone else's patches to the amp.
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17813 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 18 December 2013 - 04:26 PM
you need to use the FBV MKII or FBV MKII express floorboards as far as i know... i've not heard of anyone doing so direct through midi (doesn't mean it cant be done... i just don't know.)
#3 Harty
Harty
  • 13 posts
  • LocationGermany
  • Registered Products:10
Posted 24 December 2013 - 06:55 PM
Hello,
midi In and output can be used to edit Amp Settings and loading Patches. You need a Midi to USB Adapter. I use the Midimate II USB Adapter. It is always connected to my Laptop. I edit most Amp settings via Computer.
#4 giaturr
giaturr
  • 20 posts
  • Registered Products:6
Posted 27 December 2013 - 12:57 AM
So Harty,
Spider Edit can work via MIDI, that's good news.
What about FBV and MIDI at the same time? I'm thinking about changing presets with FBV and editing the with the computer. This is the most annoying bug in the edit software, for the non-Midi Spiders.
Thank you
#5 Harty
Harty
  • 13 posts
  • LocationGermany
Posted 28 December 2013 - 12:10 PM
I use  FBV MKII to switch between Presets, Wah and Volume Pedal while the amp is connected via Midi. You can use Midi and FBV together. So I can edit Amp settings with my Laptop (Laptop and Amp are always connected), while using my FBV to switch presets and using Wah.
#6 lleichtman
lleichtman
  • 47 posts
Posted 29 December 2013 - 10:24 PM
Uber Guru,
It actually says in the Line 6 edit program that you can connect using a midi port directly to the amp. I just can't seem to get the amp to recognize the editor program. Is there a trick to doing this? I have a shotboard MKII FBV but I get a software issue every time I try to connect the computer. It tells me to load a missing program but there are no missing programs so I am at a loss. I wish Line6 would actually support their software or hardware instead of expecting everyone on line to do it for them.
#7 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17813 posts
Posted 30 December 2013 - 06:00 AM
line6 does support their software... you should try contacting them.... instead of "everyone online"
http://line6.com/company/contact/
currently... you're basically calling the pizza place asking for an ambulance at this point....
Uber Guru,
#8 giaturr
giaturr
  • 20 posts
Posted 30 December 2013 - 06:22 AM
Great!
This could be enough to jump from Spider IV 75 to Spider Valve MKII.
Thank You.
#9 Harty
Harty
  • 13 posts
  • LocationGermany
Posted 30 December 2013 - 08:07 AM
Sometimes the Valve Edit Program doesn't recognize the midi connection, in this case I run Line 6 Monkey first, choose the correct midi drivers and run Valve Edit again. If you still have Problems try to reinstall the midi drivers on your Computer and unplug all USB devices. Look in the Device Manager of your Computer if Midi Drivers are installed correctly. If you have installed new audio drivers you also have to reinstall midi drivers
#10 lleichtman
lleichtman
  • 47 posts
Posted 30 December 2013 - 10:44 AM
Uber, I will try that again but, to date, have never gotten a response from Line6 even with a trouble ticket. That is why I try to get some info here. Believe me, I appreciate the help here.
#11 lleichtman
lleichtman
  • 47 posts
Posted 01 January 2014 - 02:06 PM
Every time I try to install a flash memory uopdate either through the FBV shortboard or directly through midi to the amp it gives me code 800000A and will not install. This is with restarting the amp in boot mode, restarting computer, every which way nothing works. Any help?
#12 Scott_TN
Scott_TN
  • 10 posts
  • LocationTennessee
Posted 04 February 2014 - 08:17 PM
I have experienced the same issue and I found that it was the quality of the Midi cable and my user error in that I was not connecting the Midi cable Out to the amp IN and vice versa. I use a Yamaha Midi cable. I recently purchased a second Spider Valve MKII 212 and I have no problems.
Thanks,
Scott_TN
My Equipment
Spider Valve MKII 112
FBV Shortboard
FBV MKII Shortboard
G55 Guitar Wireless
#13 lleichtman
lleichtman
  • 47 posts
Posted 15 February 2014 - 07:58 PM
Just want to let everyone know that all is working great now. I can edit just fine through the midi cables and spider valve edit.
Also tagged with one or more of these keywords: midi
