aggravation Posted December 19, 2013 Share Posted December 19, 2013 Is there anyway the output settings could be made to store on a per preset basis? I have the PodHD500x hooked up via L6 Link to a DT head and the XLR's into my mixer and change between presets that use one or the other for output. Trying to remember change it manually is a problem. I find my self starting to adjust the parameters on the amp model because it sounds off only to realize too late I forgot to switch Output Settings.... If not per preset then per set list? If not that then via an external midi controller? Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 19, 2013 Share Posted December 19, 2013 The output setting is global - can't be saved per preset/setlist. I'm not sure about midi control; check the MIDI section of the manual. Quote Link to comment Share on other sites More sharing options...
aggravation Posted December 19, 2013 Author Share Posted December 19, 2013 Yea, I should have been more clear. I know they are currently only adjustable as a global choice. I was wondering if anyone knows if that could be changed in a firmware update? Quote Link to comment Share on other sites More sharing options...
