Jtv Mags And Pod Hd 500
pod hd 500 jtv magnetic pickups
1 reply to this topic
#1 claybert
claybert
  • 22 posts
  • Registered Products:5
Posted 20 December 2013 - 11:03 AM
I just ran across a little issue, and wanted to confirm my suspicions... I recently made a group of patches for our Chrismas services at church and a couple of them involved using the JTV magnetic pickups (for eBow use).  I set the input for these patches to "Variax Mags", made my tweaks, and saved the patch.  When I recalled the patches during a rehearsal, I noticed that the pickup selection was not what I had originally set.  Am I correct that when using the POD HD 500 with the JTV, it will default to the neck and bridge magnetic pickups both being on when changing to the patch?
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15918 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 20 December 2013 - 11:07 AM
I suspect the physical mag pickup switch setting determines the selection. I don't think the HD500 recognizes or stores the physical switch setting that was in place when the preset was saved. Whatever position the switch is in when you select the preset - I think that's what is used.
On the other hand, .... I haven't tested this so could well be wrong here......
.... John Lennon
Also tagged with one or more of these keywords: pod hd 500, jtv, magnetic pickups
