Line6 Ux1 / Pod Farm 2.55 Plugin Feedback And Cpu Issues In Logic 9
7 replies to this topic
#1 xmulderx
xmulderx
  • 7 posts
  • LocationBerlin, DE/Tampa, FL
  • Registered Products:1
Posted 15 May 2013 - 06:29 AM
Hi there.
I have recently installed a brand new MacMini (2.6Ghz CPU, 16GB RAM) and worked on a couple of mixes with POD Farm 2.55 with the UX1 set as an output device only in Logic 9. I used the POD Farm plugin for the dry guitar signals and everything worked like a charm.
However, I wanted to record some additional guitar tracks in the very same project, so I set up the UX1 as an input device as well. As a result, I'm getting a lot of noise and feedback from the guitar signal. So much, that it's impossible to record a clean track. I have activated the noise gate/s and it doesn't help at all. Turning them off makes it worse, though.
The weird thing is, I also tried the standalone version of POD Farm 2.55 with the very same presets and the problem doesn't occur. So in Logic, I tried to bypass the only other plugin on the track (an EQ) and muted all the other tracks apart from the one that I use with POD Farm. The problem remains the same.
Also, as soon as I set up the UX1 as an input device, it maxes out one of the cores of my CPU, so it is constantly in the red.
I hope someone can help with this, because I need to work with those units/plugins. I record music for a living, so this needs to be figured out.
Thanks in advance! :)
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16057 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 15 May 2013 - 03:32 PM
In Logic, make sure you are using the UX1 ASIO driver for the device - not some other driver such as ASIO4ALL.
Also, when recording, make sure you turn OFF the Record Monitoring feature in Logic; use the UX1 as the monitor.
.... John Lennon
#3 xmulderx
xmulderx
  • 7 posts
Posted 15 May 2013 - 04:06 PM
Where do I find the settings for the driver selection?
Turning off the software monitoring helps with the CPU, but not with the feedback. And how do I make the UX1 still work as a monitor when the software monitoring is turned off with the UX1 as the output device?
#4 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7366 posts
  • Registered Products:6
Posted 15 May 2013 - 06:29 PM
Are your speakers/monitors connected to the UX?
#5 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16057 posts
Posted 15 May 2013 - 06:36 PM
Sorry - my mistake. ASIO is for Windows systems - your Mac driver should be Core Audio.
Where do I find the settings for the driver selection?....
.... John Lennon
#6 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7366 posts
Posted 15 May 2013 - 06:50 PM
It should be in Logic's Audio Preferences, I don't have a Mac, but it might just be listed as UX1.
btw, if you run Monkey do you have green ticks for drivers, firmware and PF2.5?
#7 xmulderx
xmulderx
  • 7 posts
Posted 15 May 2013 - 07:24 PM
Yeah, it's only listed as UX1 and all the ticks are green. I re-installed everything today and updated to the latest versions.
Yep.
#8 xmulderx
xmulderx
  • 7 posts
Posted 19 May 2013 - 07:36 AM
I have opened a support ticket with Line6 and it seems to be a problem that is currently investigated in general.
In the meantime, someone who's using Reaper told me he has the exact same feedback issue. I hope it's getting solved soon, I want to get back to work and be able to use the product.
