corywong Posted December 22, 2013 Share Posted December 22, 2013 80% of the time I go direct 2XLR's to the FOH, but sometimes I go into an amp....any way i can quick change my presets to do that? any master switch to do that on all presets? Quote Link to comment Share on other sites More sharing options...
joebutterfield Posted January 9, 2014 Share Posted January 9, 2014 Here is what you will need to do... 1. Hold down the view icon to access System & I/O 2. With the arrow button, scroll right over to page 4 so you can access the output configuration. 3. On this page you can configure how you want the output signal to react. 4. Depending on how you want to interface the amp with the HD500X, refer to the advanced guide page 2.8 for the right mode considering your application. Keep in mind this is a global setting, which will effect all of your presets. So I would recommend is saving all of your existing presets to a separate set list, so you have one set list optimized for Studio/Direct outputs and the other designated to connecting via your amp. Keep in mind you may have to tweak your presets when playing through your amp, but the beauty of this is when deciding either the amp or the PA all you will have to do is switch the setlist and select what output type you need to use. Hope this helps. Quote Link to comment Share on other sites More sharing options...
