latuija Posted December 22, 2013 Share Posted December 22, 2013 Hi!! How does the boost 12AX7 works in Dt 50.Where do i activate 12AX7 is in pod500 or Amp. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted December 22, 2013 Share Posted December 22, 2013 its not a boost like you think it is... its a boost from the preamp to feed into the power amp it's not supposed to be user accessible. you need to use midi to change it for the standalone DT50 use... you'd have to figure out the midi switch to manually add it on the pod... but it's really not going to do what you want... your life will be much easier to accept that and simply use one of the other boost options... compresser, eq, od, etc Quote Link to comment Share on other sites More sharing options...
latuija Posted December 22, 2013 Author Share Posted December 22, 2013 Ok thanks Quote Link to comment Share on other sites More sharing options...
Metalchef Posted December 25, 2013 Share Posted December 25, 2013 I have enabled the Boost in a few of the preamps I changed. I used it on the Slo Overdrive and it gave me some added clarity. I compare it to switching from topology 1,2, or4 to Topology 3 adds little bit of a boost like clarity not so much a boost like a pedal boost but does wonders for clarity. In my opinion. Quote Link to comment Share on other sites More sharing options...
latuija Posted December 25, 2013 Author Share Posted December 25, 2013 Ok! thanks for all the input. Quote Link to comment Share on other sites More sharing options...
