Restore Flextone Iii Factory Models
modify amp cab model
3 replies to this topic
#1 mp112849
mp112849
  • 8 posts
  • Registered Products:1
Posted 26 December 2013 - 05:46 AM
Is there a way to restore the factory model settings to their original values and without affecting the currently saved presets under the A, B, C, D buttons?  For the most part, all but one of the amp/cab models is fine.  However, there's just no way the Blackface Lux can be right.  It's very thin and the level is much lower than other similar amp/cab settings.  I suspect that the previous owner had somehow modified and saved this... if that's possible.  Hope that's the case and that I can get it back to something more reasonable.
#2 mp112849
mp112849
  • 8 posts
Posted 26 December 2013 - 07:11 AM
Sorry about the double topic post.  I was hoping I could delete one of these.
#3 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1831 posts
  • LocationGreece
  • Registered Products:12
Posted 26 December 2013 - 05:23 PM
Well, no, it's no possible without loosing the a.b,c,d.what you can do, is take a midi cable, connect it to the amp-computer, and save the a-b-c-d bsnks, or see their presetes and write them down before you make a factory reset.
Before line6 was called line6... they used to do r&d for other companies like alesis + others. and when those customers came to visit the offices of line6 (before it was called line6) and the receptionist needed to warn all the guys who were designing products for other companies (and for themselves... ) who were like 'in the back' the receptionist would announce over a tannoy 'tellephone call for 'fred smith' on line 6' the cunning part was that they only had 5 telephone lines, so it was the secret code for "hide your sh1t the feds are comin'" or "someone's coming, let's hide these PODs that we aren't going to release for another few years so they don't see them"
BEST CABS: www.studiocat.com
#4 mp112849
mp112849
  • 8 posts
Posted 28 December 2013 - 07:50 AM
The problem is that I do not have computer/amp bi-directional communication via midi.  I've tried the MIO usb interface and the M-Audio MIDISport UNO usb interface and neither of those work.  MIDI out of computer to MIDI in of amp work OK... I think, since I see activity on the UNO Out LED, but I see nothing on the In LED.  I'm pretty much arriving at several conclusions:
  1. Since I keep seeing MS GS Wavetable synth device in windows 7 64 bit control panel there may be a windows issue
  2. The MIDI out port on the flextone may be malfunctioning, but I have no way to test that.
One thing I did was check to see the amp and cab combinations for the Blackface Lux.  If I'm reading the manual in the cabinets section correctly, the combination of Blackface Lux and Jazz Clean should be the right thing.  When I initially checked, it was mapped to the '53 Celestion Blue Bell.  What I'm not sure of is whether the mapping should be Blackface Lux -> Fender '63 Vibroverb.
So I believe I have the amp/cab setup correct now, unless someone can tell me different.
I'd like to know if there's some diagnostic I can perform to test the midi ports on the flextone.
Also tagged with one or more of these keywords: modify, amp, cab, model
