[help] Pod Hd300 Error
pod hd300 error help
12 replies to this topic
#1 mekel1991
mekel1991
  • 2 posts
  • Registered Products:1
Posted 15 May 2013 - 10:57 AM
Help me please. My pod HD300 suddenly became very weird. When i turn it on, after a few minutes it always activate "auto volume" effect, and its happened in every preset whether i turn off FX3 or turn on another FX3 channel (like delay), it will suddenly change into autovolume effect. I've done several things, like reset to factory setting, unplug replug the effect.
Thank you
#2 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5384 posts
  • Registered Products:6
Posted 15 May 2013 - 11:19 AM
Sounds like you might need to calibrate the pedal...If I recall correctly, power up holding the D button and follow the prompts.
#3 mekel1991
mekel1991
  • 2 posts
Posted 16 May 2013 - 09:52 AM
ive done that, and it didnt worked.
Actually i think thats not the real problem, coz it's not a volume pedal problem, but it's an effect problem ( suddenly active itself)
#4 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5384 posts
Posted 16 May 2013 - 11:07 AM
ok...keep in mind that if the volume pedal calibration is not good is can have an effect much like what you describe.  knob jitter?...not sure...but it can cause weird volume fluctuations as well. A bad pot on the channel volume or drive can make things strange....you could try setting all the knobs to zero (other than the master of course) ...recall some patches and see if you still have the problem...Other than that, I can think of much else other than perhaps the gate is on and set strange...Or maybe you are using an active guitar and the battery is going flat...If you can't narrow down to a cause you might need to get it serviced.
#5 nevydskrest
nevydskrest
  • 1 posts
  • Registered Products:2
Posted 26 January 2014 - 11:08 AM
I am having the same problem, on the digital screen it automaticaly changes to Auto volume. something wierd here. I need help because I use this everyweekend!
#6 bowie1026
bowie1026
  • 1 posts
Posted 18 April 2014 - 11:06 PM
Hello there,
I am having the same problem here.
What are the possible remedies ? I know sending it for service is a solution, but I would like to know what causes it, because from here we can tell that I'm not the only one who face this problem...
#7 dshipley
dshipley
  • 3 posts
  • Registered Products:3
Posted 09 July 2014 - 07:06 PM
Anyone make any progress with this?  I'm having the problem with my HD400 . . . I'll be playing along, and randomly get the auto volume take-over.  I can flip patches and get it back to normal . . . but of course, that's not going to be an option performing.  :(
#8 nachodividido87
nachodividido87
  • 3 posts
Posted 27 August 2014 - 01:08 PM
I'm having a similar problem with my HD400. But instead of activating the "auto volume" effect, it randomly turns up or down any of the FX1, FX2, FX3 knobs of the "Smart FX" controls and the reverb knob too. It can be seen in the screen when it happens. I'm not quite sure what causes it, but I suspect that it has to do with the footswitches. Maybe hitting them a little harder than necessary causes this failure. Does anyone knows if it can be solved or fixed?
#9 dshipley
dshipley
  • 3 posts
Posted 27 August 2014 - 05:50 PM
Update from my last post.
My problem got steadily worse until it was in a permanent state of edit mode.  Even unplugged everything.  Plugged the POD back in with nothing attached, switch patches, nothing worked . . . totally unusable.
Took it in for service . . . couldn't reproduce the issue (typical).  Even took my whole rig into the shop and hooked it up . . . everything worked like a charm . . . no issue.  Got it back home and did two things:  1) New wall plug and power strip (I know it's a long shot, but thought power fluctuation might have something to do with it); and, 2) left off my busta grande pedal I was running through the effects loop (more likely the issue).  Everything has worked fine.  I left if this way until I played a show last week (didn't want to risk the problem coming back when I had a gig coming up).
Now that I don't have a show for a few weeks, I'm going to try plugging the busta grande back in the loop and see if the problem comes back.  If not, I'll revert back to the old power strip and plug and see if that does it.  I'll post back if there are any results.
#10 neBelorz
neBelorz
  • 1 posts
Posted 15 February 2015 - 11:35 AM
anyone got tips for this problem? I was playing, with USB connected and it suddenly started to switch on the FX constantly (and still doing this....) :S
#11 deg65
deg65
  • 2 posts
Posted 24 April 2015 - 08:23 PM
Same problem solution?
#12 deg65
deg65
  • 2 posts
Posted 29 May 2015 - 07:27 AM
solution?
#13 dshipley
dshipley
  • 3 posts
Posted 29 May 2015 - 07:45 AM
Are you running anything through the effects loop?  I haven't had time to do more troubleshooting, but I suspect there's something flaky with the loop.
Also tagged with one or more of these keywords: pod hd300, error, help
