Loekito Posted December 30, 2013 Share Posted December 30, 2013 I just purchase my JTV-59, and the next day after I arrive on my home country, then I start to play with it. And I notice, that pushing the alt-tuning knob won't change the current 2-3-4 selector configuration to 1-3-5 ones. What I can recall during trying the guitar in the shop, when I push the alternate-tuning knob, then the light on the model knob will turn from blue into white (or slight of red hue?) and vice versa. Is this correct? But now, when I push the alt-tuning knob, nothing happend, the light on the model knob is remain blue, and the switch selector is stay on the 2-3-4 configuration. But I can select the model on the 1 and 5 position via POD HD500. I already un-plug the "knob", and directly push the potentio shaft, and it's also don't have any effects. I already try to flash the firmware several times, it's also got no effects. Is the "push" action on my alt-tuning knob broken? (note: the alt-tuning selection is working fine by dialing/rotating on it). Is there any way to perform a diagnostic, to make sure whether it's a hardware (the potentio) fault or software (firmware) fault ? Any you guys here encounter the same problem with me before? Thanks & regards, Loekito Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 30, 2013 Share Posted December 30, 2013 ... I already un-plug the "knob", and directly push the potentio shaft, and it's also don't have any effects. ...... Is the "push" action on my alt-tuning knob broken? (note: the alt-tuning selection is working fine by dialing/rotating on it). ..... I would have suggested that you remove the knob and push down on the shaft as a test. Since you've already done this with no success, and have already reinstalled the firmware, I think there must be a hardware problem with whatever trigger is under the shaft. I would open a support ticket to work directly with Line 6 to resolve this. http://line6.com/support/tickets/add.html Quote Link to comment Share on other sites More sharing options...
Loekito Posted December 30, 2013 Author Share Posted December 30, 2013 Hai Silverhead, thanks for your reply, do you know what kind of the potentiometer used on the alt-tuning knob? is it a regular potentiometer that we can purchase on guitar-parts store? or it's specific/special-made potentiometer by Line 6 ? Note: I'm not staying in the same country where I purchase the JTV. Thanks, Loekito Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 30, 2013 Share Posted December 30, 2013 I don't know. I suspect it's a special rather than regular switch/potentiometer. Again, I think you should open a support ticket so that you can ask this question to Line 6 directly. Quote Link to comment Share on other sites More sharing options...
Loekito Posted December 30, 2013 Author Share Posted December 30, 2013 okay, thanks a lot.... Quote Link to comment Share on other sites More sharing options...
