G50 Fuzzes And Distorts When Guitar Volume Fades Out.
relay g50 fuzz distorts
3 replies to this topic
#1 rsto10
rsto10
  • 51 posts
  • Registered Products:5
Posted 16 May 2013 - 11:20 AM
I have a Relay G50.  The other day I was playing some clean tone stuff and noticed that if I hit a chord and let it ring, the sound started clear but began to fuzz, crackle, and break up as the sustain from the guitar faded.  If I roll back on the guitar volume and pick very lightly, everything I play at low volume is distorted and fuzzy.  I use a DT-50, so at first I thought it might be related to the tubes, but when I removed the Relay from the signal and used a cable, there was no issue.  Definitely a G50 issue.  I had the firmware updated by a service tech who sent it out to Line 6 when the cable connection on the transmitter needed to be repaired, so it is the latest firmware to the best of my knowledge.  I've tried switching channels, I've tried Lo and Hi power.  Any ideas?
Thanks!
Helix
JTV-59
DT-50 112 Combo
DT-25 Combo
HD500X
HD500
Stagesource L2m and L2t
Relay G50
Relay G70
#2 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
  • Registered Products:1
Posted 16 May 2013 - 12:22 PM
battery?
I'M SO HAPPY!
#3 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
  • Registered Products:4
Posted 16 May 2013 - 04:55 PM
The possibility of a hardware failure is always present but there's no way to know with the limited info presented. I would test the Relay by passing recorded music into the transmitter and plugging the receiver into a PA system ( not a guitar amp since guitar amps are built to add coloration to the signal)
Let us know what happens
#4 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
Posted 16 May 2013 - 04:57 PM
battery?
Battery level rarely makes any difference to signal quality. Remember we are only sending ones and zeros so whether they are full strength or nor they are still only ones and zeros
Also tagged with one or more of these keywords: relay g50, fuzz, distorts
