Hd500/500x With Acoustic Guitar?
Best Answer GuitarMan53 , 04 January 2014 - 04:25 PM
Thanks, guys. That will be enough for me to run with. chuskey, I had actually thought about using the no amp setting and just shaping it with the reverb, chorus, etc. With My Taylor PS14ce, I won't need a lot there, because of the expression system built into it. Now, I just need to decide between the 400 500, and 500X
Go to the full post
9 replies to this topic
#1 GuitarMan53
GuitarMan53
  • 5 posts
  • Registered Products:5
Posted 03 January 2014 - 11:35 PM
Can anyone tell me if the amp models in the HD series work well with an acoustic guitar plugged in? I have a PODxt that had a couple of acoustic amlp models, but it will no longer connect to my computer. Trying to find out what my options are.
#2 alexisltd
alexisltd
  • 53 posts
Posted 04 January 2014 - 06:47 AM
http://www.youtube.c...h?v=stg_npwC3M4
http://www.youtube.c...h?v=NAm9Lf0Vvww
#3 chuskey
chuskey
    Iknowathingortwo
  • PipPip
  • 311 posts
Posted 04 January 2014 - 07:15 AM
I think the HD500 works great with acoustic.  I wouldn't recommend using the amp models though.  Just turn the amp model off and get what you need via EQ, Compression, Reverb, etc.
Here's a clip I did messing around in the studio using my JTV59 for acoustic sounds into the HD500.  I like the sounds I'm getting.
#4 BlueViolince
BlueViolince
    Iknowathingortwo
  • PipPip
  • 319 posts
  • Registered Products:2
Posted 04 January 2014 - 07:29 AM
Hiwatt model. 112 field coil cabinet with 4038 ribbon mic, ER and sag at 100 percent. This is what I use for electric violin, so your mileage may vary.
#5 GuitarMan53
GuitarMan53
  • 5 posts
Posted 04 January 2014 - 04:25 PM   Best Answer
#6 hardins1
hardins1
  • 19 posts
  • Registered Products:4
Posted 04 January 2014 - 07:26 PM
hey Chuskey can you post yor patch for the video I love it...
#7 chuskey
chuskey
    Iknowathingortwo
  • PipPip
  • 311 posts
Posted 04 January 2014 - 10:25 PM
That clip was from a few months ago and I've noodled around with the effects a little bit.  But I haven't changed the core tone settings which are EQ, compression, and reverb.
Here's a link to the patch:
http://line6.com/cus...ne/tone/257095/
#8 chuskey
chuskey
    Iknowathingortwo
  • PipPip
  • 311 posts
Posted 04 January 2014 - 10:28 PM
I forgot to mention that it was recorded with a 500, but I'm using a 500X now.  I just imported the patch when I upgraded, so it's now in the .5xe format.  I'm not sure if it's backwards compatible with the regular 500, but I would think it would be.
#9 chuskey
chuskey
    Iknowathingortwo
  • PipPip
  • 311 posts
Posted 04 January 2014 - 10:31 PM
I always recommend getting the best one you can fit into your budget.  A used 500 is probably the best value at the moment.  If you're mainly doing acoustic and don't need the amp modelling I doubt you'll ever hit the DSP limit.
I really like the flexibility of the 500/500X.
  • 1
#10 GuitarMan53
GuitarMan53
  • 5 posts
Posted 05 January 2014 - 10:48 AM
I play at my church mostly, and our current, interim worship leader prefers acoustic. That could change when we get a full time guy, though,. I would use the other stuff at home for fun and recording, etc. I've had an Epiphone Dot for a while and just bought a Les Paul Standard Pro. So I will get some use out of the models. Probably wouldnt come near the DSP limit anyway, unless I was just experimenting. But I like the improvements in the board on the 500X. May have to wait a bit and save up for it. I can still use my POD XT for live sound, Just can't save the presets int the computer or use it as an interface. Thanks for all your input. And nice clip, BTW
