Ux2 No Audio From Speakers Or Headphones
audio sound speakers ux2 signal
7 replies to this topic
#1 PaulGreenleaf
PaulGreenleaf
  • 3 posts
  • Registered Products:1
Posted 05 January 2014 - 02:18 PM
This seems like a simple problem, but I haven't found any sufficient answers through my two hours of scouring the internet!  Needless to say, it's driving me a little crazy.  It was working just fine less than 24 hours ago!
There is no sound whatsoever coming out of my speakers or headphones (each plugged in to the appropriate ports).  Monkey is all updated; green checks everywhere. Output knob and phones knob are at maximum.  Input/Output in Mac preferences is set for UX2.  I've tried switching out usb cables and trying different ports.  Tested headphones and speakers on other devices, they work. The only thing that changed was that I pulled out the usb cable and put it into a usb hub for a moment, then took it out and put it right back into the mac directly (I forgot, no hub with the UX2).  Right after that, it stopped working correctly.
Also, when I try to use logic pro X and gearbox, it doesn't register any sound coming from the mic, and when I try to play back something I recorded just a few days ago using the exact same settings, I get this message:
Error while trying to synchronize Audio and MIDI Sample Rate 23482 recognized.
Check conflict between Logic Pro X and external device.
I use a mac with OSX 10.9.1, fully updated.
The UX2 has power, the meters are at min and don't move, and the clip lights seem to be stuck on to orange.
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16062 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 05 January 2014 - 02:40 PM
I would try restarting the Mac. if you haven't already.
.... John Lennon
#3 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1833 posts
  • LocationGreece
  • Registered Products:12
Posted 05 January 2014 - 03:05 PM
Reinstal drivers and pod farm
Before line6 was called line6... they used to do r&d for other companies like alesis + others. and when those customers came to visit the offices of line6 (before it was called line6) and the receptionist needed to warn all the guys who were designing products for other companies (and for themselves... ) who were like 'in the back' the receptionist would announce over a tannoy 'tellephone call for 'fred smith' on line 6' the cunning part was that they only had 5 telephone lines, so it was the secret code for "hide your sh1t the feds are comin'" or "someone's coming, let's hide these PODs that we aren't going to release for another few years so they don't see them"
BEST CABS: www.studiocat.com
#4 PaulGreenleaf
PaulGreenleaf
  • 3 posts
Posted 06 January 2014 - 01:18 PM
Tried uninstalling and reinstalling all drivers, resetting the mac, and installing pod farm 2.  Still the same problem.
I also noticed when I set the audio preferences in my macs input/output to the ux2, it slows down youtube videos (still no audio), and when I switch it back to built-in, the videos resume their normal pace.
#5 PaulGreenleaf
PaulGreenleaf
  • 3 posts
Posted 13 January 2014 - 01:17 PM
Is there any way to test if this is a hardware problem?
#6 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 13 January 2014 - 02:00 PM
Try it on another computer.
#7 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
  • Registered Products:6
Posted 14 January 2014 - 05:39 AM
+1 to BigChas52
Since you are using Gearbox I'm guessing this is an older red faced Toneport and not a black faced Pod Studio?
If it is an older Toneport you should try using POD Farm 1.12 instead of Gearbox, it replaces Gearbox for the the Toneports.
If it is a black faced POD Studio, it is likely bundled with POD Farm 2.
#8 jdamaren
jdamaren
  • 2 posts
  • Registered Products:4
Posted 22 January 2014 - 05:17 PM
I am having the same problem with a PC. It was working fine last time I used it, now no sound. I haven't connected anything different. Cables checked. Drivers re-installed. Meters show input when I set it to input, however no output from monitors or headphones. Help?
Also tagged with one or more of these keywords: audio, sound, speakers, ux2, signal
