No Power To Jtv-89 From Pod Hd Pro
pod hd pro no power jtv-89 variax
5 replies to this topic
#1 Ivarsson
Ivarsson
  • 22 posts
  • Registered Products:1
Posted 10 January 2014 - 03:17 AM
Hi!
I have a simple question that I hope someone can answer for me. I just need a sanity check before sending my Pod HD Pro back to the store.
The problem is that when I connect my jtv-89 to my Pod HD Pro using variax interface I get no power to the guitar. Using the battery with the guitar works fine and when I connect the guitar to a Pod X3 Pro (using variax interface), it also works fine. So, are there any special settings on the Pod HD that I need to set or something? I couldn't find any information regarding this in the manual but I just want to make sure I'm not missing something obvious. And yes, I've set input to variax.
Thanks!
/ Mattias
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 10 January 2014 - 04:47 AM
could be the cable try a standard cat5/cat6 network cable between the variax and the pod and see if that works.
#3 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 10 January 2014 - 06:36 AM
Sounds like you got a bad Pod HD.  It should power your Variax over the VDI cable.  If your VDI works elsewhere it must be a defective Pod - lacking the power connection.
#4 Ivarsson
Ivarsson
  • 22 posts
Posted 10 January 2014 - 02:50 PM
I tried a 2nd cable with the same result so I guess the Pod is to blame.
I'll mark this as solved as soon as I get some info from repairs.
Thanks for your answers!
Cheers!
/ M
#5 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 10 January 2014 - 03:13 PM
may not be the pod etc... i'd inspect the cable sockets... could be a bent pin on either end... something simple like that...
usually happens on the variax side where a guitar plug was accidentally attempted to insert in the wrong jack.
#6 AndyParedes
AndyParedes
    Line 6 U.S. Product Specialist
  • Product Specialist
  • PipPipPipPipPip
  • 4486 posts
  • LocationCalabasas, CA - USA
  • Registered Products:8
Posted 10 January 2014 - 04:24 PM
+1 to Zap - I have seen this a few times as well.  You may want to try your JTV on a different HD500/X/Pro to see if it is getting power there, or a different JTV with your rig to ensure you are sending the correct piece of gear for repair.
Regards,
Andy
@line6aparedes
http://line6.com/tone-templates/
Also tagged with one or more of these keywords: pod hd pro, no power, jtv-89, variax
