Mightych Posted January 11, 2014 Share Posted January 11, 2014 Just got an HD500X and the second I plug the USB in all media on my computer freezes (Spotify, WMP, Youtube). If I unplug they start playing again. The driver is installed and Monkey says it's connected. Also I get a connection error when I try to flash it. I'm assuming this is a driver problem, but I'm using the driver that Monkey grabs for me so what gives? Quote Link to comment Share on other sites More sharing options...
Mightych Posted January 11, 2014 Author Share Posted January 11, 2014 I just did a fresh install of Windows 7 (64-bit) and only installed the chipset and USB Wi-Fi drivers. Then I installed the HD500X driver and it said it installed correctly. Started WMP, plugged in the unit and WMP froze until I unplugged it. Grrrr. Quote Link to comment Share on other sites More sharing options...
Mightych Posted January 11, 2014 Author Share Posted January 11, 2014 Okay, I was mistaken. This time Youtube videos and WMP didn't freeze, I just didn't have any audio. Plugged my sound system back into the POD and I now have audio. So, something else that was installed was causing the conflict. Looks like I just need to install everything one at a time to find the offending device or driver. Quote Link to comment Share on other sites More sharing options...
gckelloch Posted January 12, 2014 Share Posted January 12, 2014 I'm still on WinXP. There are settings you should make to your system so the audio runs smoothly with external A/I devices. Look into that. It is recommended in WinXP to disable the MB audio when using another A/I device. If the MB audio is active while using the Pod through USB it may cause freezing or stuttering. At the very least, make sure any app assigned to the MB audio is not running when you plug in the Pod. Then, assign the Win7 Sound CP to the Pod. Not sure about W7, but I think you still need to stop the USB device before unplugging it, or you'll need to reboot before plugging it back in. Quote Link to comment Share on other sites More sharing options...
