Using A Powered Non Line 6 Sub With 2 L2t's
Best Answer dboomer , 12 January 2014 - 08:42 AM
You'll need to add a crossover in the setup. Possibly there is a crossover in the other sub. In that case you run from the main outs to the sub and then run the high pass outs to the L2's. Otherwise you'll need to run into a crossover and send the outs from it in the normal manner. Go to the full post
4 replies to this topic
#1 malcevansmusic
malcevansmusic
  • 72 posts
  • LocationUK
  • Registered Products:5
Posted 12 January 2014 - 05:04 AM
Hi!
I hope everyone is having a great 2014 so far?
Just a quick question that the pro's may be able to help me with. I'm running a M20d and 2xL2T speakers (and 4 powered Behringer monitors). I've been asked to engineer a gig next month and it was suggested that I'd need a sub speaker to augment the set-up.
How would I link a powered sub (non Line 6) to the L2T's? Is it simply a case of linking with XLR speaker cables in the appropriate way (into the sub then out to the speakers)?
Any advice appreciated.
Thank you.
Malc
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15918 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 12 January 2014 - 05:53 AM
Yes - just connect them as you would normally. Run the Main Outs to your sub, then connect the 2xL2t using the XLR rather than L6 LINK connections.
.... John Lennon
#3 Profett
Profett
  • 13 posts
  • Registered Products:8
Posted 12 January 2014 - 07:37 AM
Why not connect the l2ts with 6link?
#4 malcevansmusic
malcevansmusic
  • 72 posts
  • LocationUK
Posted 12 January 2014 - 07:47 AM
Thanks! I've been doing a bit of reading since posting at I think I know what to do now.
I don't have the link cable, just XLR's.
#5 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
  • Registered Products:4
Posted 12 January 2014 - 08:42 AM   Best Answer
