Pod Hd Emulation Question.
Jeremy_Shirland
If you have a Pod HD400, I believe you could set the output switch on the back to 'Dual', where left has the speaker/mic and right has the direct sound.  Then, you could blend them using a separate small mixer.
On the HD500, you'd have to run two separate amps.  That's one place where the HD400 potentially has an advantage.  You may not be able to do this on a 500 while still getting all the effects you want, whereas you may be able to on the 400.
