Two Questions About The Hd500x
pod hd 500x l6 link dt25
3 replies to this topic
#1 wanderer80
wanderer80
  • 3 posts
  • Registered Products:1
Posted 12 January 2014 - 10:00 PM
Hi all, have two quick questions about the HD500X:
1.  What do you find gives best results as far as System I/O goes? (I.e combo front etc)
2.  The other night I was playing through some patches I had made and was adjusting channel volume and for some reason it keeps resetting the channel volume back to 100 even when I save at lower volume, any tips or tricks?
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17846 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 13 January 2014 - 10:26 AM
1. depends on what you are playing through... as that's the general purpose of that setting. use your ears and use the one that pleases you if you disagree with the "correct one"
2. sounds like it wasnt saving properly, i can't think of a scenario that would otherwise produce this result.
#3 sonic
sonic
  • 43 posts
  • LocationHaacht, Belgium
  • Registered Products:2
Posted 13 January 2014 - 11:05 AM
Regarding question nr. 2 : is the channel volume controled by the expression pedal ? I noticed that it does not make a difference at what volume you set it as long it is controled by the expression pedals...
Sammy
Line6 DT25 head and cab, Line6 HD500, Line6 JTV 59.
Marshall JVM 410H, 1960 AX cab.
Gibson SG Standard.
Steinberger GM 4S (Newburgh).
#4 bvaladez74
bvaladez74
    Iknowathingortwo
  • PipPip
  • 183 posts
  • LocationSan Jose, CA
Posted 18 January 2014 - 01:37 PM
Sonic is right.  I'd bet that preset has the exp pedal turned on.....so if you manually adjust the volume and try to save it, it'll revert back to what the exp pedal is saved at.
Also tagged with one or more of these keywords: pod hd 500x l6 link, dt25
