jb12string Posted January 16, 2014 Share Posted January 16, 2014 I purchased the HD-500X and a Mission EP1-L6 about a month ago. So far, I like everything except the way the volume pedal function works when assigned to the Mission, the taper is a little, well, off. It seems like the volume increases very fast when coming from heel down and it doesn't change much when you get close to toe down. I talked to mission about it, they confimed that putting a resistor on the cable will change the taper and make it work better, but it was more of a hack than a fix and that it only seems to be an issue with the pedal when used as a volume control. They hinted that it seems to be more of a firmware issue. Is there any likelyhood of a firmware update that will fix this anytime soon? 1 Quote Link to comment Share on other sites More sharing options...
jb12string Posted January 21, 2014 Author Share Posted January 21, 2014 Bump? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted January 21, 2014 Share Posted January 21, 2014 you might want to ask support: http://line6.com/company/contact/ (open a ticket) have you tried other "tricks" to see if you get better results? such as assigning the pedal to control the channel volume of the amp rather than assigning it as a volume pedal? (this saves you an FX slot as well) Quote Link to comment Share on other sites More sharing options...
bvaladez74 Posted January 23, 2014 Share Posted January 23, 2014 Its not a line 6 support issue. That particular mission pedal isn't 100% accurate. Mission support will stutter when you ask them about it...but bottom line...I returned mine. Wasn't worth the headache. Quote Link to comment Share on other sites More sharing options...
