Pod Mount
Best Answer silverhead , 16 January 2014 - 03:34 PM
From the linked post I see this:
NOTE: If POD is face down on its front, Front Length = Lower 2 holes and Rear Length = Upper 2 holes.
I presume 'screw length' refers to the length of the screw for the respective two screw holes.
Go to the full post
3 replies to this topic
#1 frac82
frac82
    Iknowathingortwo
  • PipPip
  • 121 posts
  • Registered Products:2
Posted 16 January 2014 - 03:31 PM
hello everybody. found this post about the POD mount accessory; I'd like to understand better what "screw front and rear length" is meant to be... thanx.
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15698 posts
  • LocationOntario, Canada
  • Registered Products:15
Posted 16 January 2014 - 03:34 PM   Best Answer
.... John Lennon
#3 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 16 January 2014 - 03:36 PM
the length of the screw for the front, the part of the pod nearest you and the length of the screw for the rear, the part of the pod away from you on the bottom of the pod.
I'M SO HAPPY!
#4 frac82
frac82
    Iknowathingortwo
  • PipPip
  • 121 posts
Posted 17 January 2014 - 12:06 AM
pretty clear, thanks both of you!
