Topology Switch With/without Podhd Connected
13 replies to this topic
#1 aggravation
aggravation
  • 87 posts
  • Registered Products:1
Posted 17 January 2014 - 06:31 AM
If I understand it correctly (large assumption on my part...) switching topology I, II, III andIV with PodHD connected via L6 Link lets you decide the negative feedback loop configuration and the preamp choice stays as the PodHD preset dictates.
However, if you don't have a PodHD connected it is switching the preamp model assigned to that switch position. To assign the negative feedback loop characteristic you have a separate control in the DT Editor.
So is the negative feedback solution strictly a software modeled component or is there some relay switching going on that doesn't take place when the PodHD isn't connected?
#2 talwilkins
talwilkins
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationNetherlands
  • Registered Products:6
Posted 17 January 2014 - 06:42 AM
If you ask me the negative feedback is changed by relay switching, with or without connected PODHD.
The difference is that without the POD, the DT also changes Pre amp modelling.
With the POD connected the pre amp is comming from the POD and stays as is.
  • 1
Music is the best (FZ)
the Zombywoof
#3 aggravation
aggravation
  • 87 posts
Posted 17 January 2014 - 07:42 AM
If that is so then you couldn't put just any preamp in any of the four positions and expect it to stay true to its model.
You would have to put only type I preamps in slot I....etc.
#4 talwilkins
talwilkins
    Iknowathingortwo
  • PipPip
  • 436 posts
Posted 17 January 2014 - 08:07 AM
That is indeed the case, as far as I understand.
Don't forget that without the POD the DT is Just a "simple" Two channel amp.
the Zombywoof
#5 aggravation
aggravation
  • 87 posts
Posted 17 January 2014 - 08:36 AM
I dont see it that way, I have 4 different preamps on channel A and 4 different on channel B. So by using the channel toggle and the topology toggle, without the PodHD connected I'm switching between 8 different distinct sounds. The tone stack and volume, gain, etc of A is shared by its 4 preamp choices... the same with B, but other than that it is more of an 8 channel amp than 2.
#6 stumblinman
stumblinman
    Gear Head
  • PipPipPip
  • 882 posts
  • LocationPacific Northwest
  • Registered Products:2
Posted 17 January 2014 - 08:58 AM
It is 2 channel footswitchable, 8 channels available. You are both right.
#7 stumblinman
stumblinman
    Gear Head
  • PipPipPip
  • 882 posts
Posted 17 January 2014 - 09:01 AM
You can match any topology with any amp model using DT edit. You can also change the topology of the hd500 model running into the DT by changing the switch on the amp while the Pod is connected. You can mix em up, which I do, as it gives me sounds I want, or leave them true to the models. It's great to have choices.
#8 talwilkins
talwilkins
    Iknowathingortwo
  • PipPip
  • 436 posts
Posted 17 January 2014 - 09:20 AM
Great!
I see now. There are two channels (A and B ).
Each channel can be one of four "programs" consisting of any combination of the parameters.
Wonderful! :)
Thanks for clearing this up.
the Zombywoof
#9 tearitupbaby
tearitupbaby
  • 60 posts
Posted 04 February 2014 - 09:46 PM
i am still confused...How do you get all the other types of amps bvesides 4 without a computer?
#10 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
  • LocationOrange County, NY
  • Registered Products:3
Posted 04 February 2014 - 10:15 PM
you don't unless you have a POD HD.  The only way to access them and make changes is by midi connection to a computer with DT Edit.  otherwise you only have what it came with.  If you have a POD HD you don't need to change them because all the same amps are in the POD.
#11 ColonelForbin
ColonelForbin
    Power User
  • PipPipPipPip
  • 1683 posts
  • LocationChicago, Illinois
Posted 05 February 2014 - 02:02 PM
How does the new DT firmware update impact this?
DT Firmware 2.0
"Available as a free download, v2.0 firmware takes your DT amp from four voicings to total flexibility. Create never-before-heard amp tones by pairing any of 30 HD preamps with any combination of dynamic topologies within Reinhold Bogner’s reconfigurable tube power amp."
#12 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
Posted 05 February 2014 - 02:14 PM
that is what allowed you to choose from 30 different amp models for your 8 saved configurations.  It doesn't change any other things related to accessing those saved modesl.  You still basically have a 2 channel amp with 4 variations for each channel.
#13 nikoniablue
nikoniablue
    Iknowathingortwo
  • PipPip
  • 102 posts
  • LocationSt Albans, England
Posted 07 February 2014 - 01:50 AM
DT Firmware 2.0
The update allows you to programme in the full range of HD500 preamps into the DT rather than just the four in the original firmware.  You no longer need an HD500 to get access to those sounds - it is done over midi.  If you have an HD500 it's of little benefit as you could get to those sounds via the HD500 anyway. But it's pretty cool if you have specific sounds you want and don't want to go via HD500.  To my ears it gives a better sound if you go straight from guitar to DT than if you go via HD500 (less processing?).  The update also allows you to change the reverb effect associated with each channel setting (again over midi).
#14 aeugle
aeugle
    Iknowathingortwo
  • PipPip
  • 153 posts
  • LocationMunich, Germany
Posted 09 February 2014 - 03:19 AM
To my ears too!.
