Kb37 Is Buggin'
pod studio kb37
4 replies to this topic
#1 Skitzolinguistiq
Skitzolinguistiq
  • 2 posts
  • Registered Products:1
Posted 20 January 2014 - 05:54 AM
I switched all my gear over to Mac tonight and wish I never did. All of it was working fine on my PC. The only problem was how slow it ran. Anyways, I reinstalled Reason 7.0.1, authorized it, got Pod Farm back with it's Monkey, set all my preferences and all was well. Then I checked to see if the Monkey had any updates for me. The drivers and the USB firmware updated just fine. Then when I got to the Flash Memory, my KB37 shut down. All I got was the clip lights blinking back and forth. So, I tried again as instructed; unplugging it when prompted and got the same result a couple of times. I tried one last time and am now stuck with the level needles pushed as far passed max as they could go and mostly all the octave select lights red (-3 isn't lit at all and the middle light is green).
I need some help. I have almost spent all my money on this equipment and really can't afford to replace any of it. I have the extended warranty thingy for it but i'm not too sure what coverage it includes. I read some other forums when folks had similar issues with updating. I just don't know if that's what my problem is. Please help if some of this sounds familiar or you just know what i can do. Thanks.
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
  • Registered Products:6
Posted 20 January 2014 - 07:14 AM
What OS on make are you using?
#3 Skitzolinguistiq
Skitzolinguistiq
  • 2 posts
Posted 20 January 2014 - 11:11 AM
Sorry, I thought I responded with my phone earlier. I guess it would't go through. Anyway, I'm running OS X Maverick.
#4 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
Posted 20 January 2014 - 11:27 AM
First make sure your Mavericks is updated, it had some initial issues.
Also, make sure you have newest Monkey installed.
http://line6.com/software/
also, check out this link for a possible work around. Seems like this may be a Mac issue with their Fusion drives.
https://discussions....772261#23772261
Please post results if you try this.
If it were me I would try to see if it still works on a pc.
#5 icorra
icorra
  • 9 posts
Posted 14 February 2014 - 06:45 PM
I have the same problem but my iMac has a normal 1 TB drive at 7200 rpm.
Thx
Also tagged with one or more of these keywords: pod studio, kb37
