Treble Booster From Hd500x?
treble booster hd500x
13 replies to this topic
#1 joakey
joakey
  • 4 posts
  • Registered Products:1
Posted 21 January 2014 - 04:09 AM
Hi, I have a Brian May Special guitar and the pickups are wired in parallel, which apparently makes the sound heavier on the bass when you have more than one pickup selected (you can select all three, as they have individual switches).  That's why Brian May himself plays with a treble booster all of the time.
I've checked the list of effects on the HD500X (useful background information: I have one!) and I don't see a treble booster.  Is there another pedal on the pod that would produce the same effect?  Is it different from just whacking up the treble knob on the amp?  Or would it be simpler if I just buy a treble booster?
Thanks for any thoughts! ;)
#2 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 21 January 2014 - 04:58 AM
Try "Blue Comp Treb" from the "Dyn" section (Based on* the Boss® CS-1 Compression Sustainer with the treble switch on).
#3 alexisltd
alexisltd
  • 53 posts
Posted 21 January 2014 - 06:02 AM
on all electric guitars pickups are wired in parallel (unless you modify it and put a switch to change routing)
#4 Metalchef
Metalchef
    Iknowathingortwo
  • PipPip
  • 197 posts
  • Registered Products:2
Posted 21 January 2014 - 06:30 AM
You can use the Blue Comp treble but I would give the Q Filter a shot.
Yes I hear the cries of the carrots.... For it is harvest day and to them it is the Holocaust..... So I say let the rabbits wear glasses....
#5 Akeron
Akeron
    Iknowathingortwo
  • PipPip
  • 448 posts
Posted 21 January 2014 - 08:22 AM
Q Filter + Colordrive
#6 rublalup
rublalup
    Iknowathingortwo
  • PipPip
  • 157 posts
Posted 21 January 2014 - 09:10 AM
i think the standard is to wire them in series not parallel.
#7 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2513 posts
  • Registered Products:6
Posted 21 January 2014 - 09:36 AM
Not true.  I am pretty sure that most guitars like Strat wire the pickups in parallel when you select two pickups (positions 2 and 4).
#8 alexisltd
alexisltd
  • 53 posts
Posted 21 January 2014 - 11:13 AM
wiring schematics for strats and les pauls
#9 rublalup
rublalup
    Iknowathingortwo
  • PipPip
  • 157 posts
Posted 21 January 2014 - 11:26 AM
well i´ve made some pu installs on my guitars and i even got one wired in series and a switch to put that pu on parallel... so maybe i´m nos following something here. I mean if i select the neck pu of my guitar that one is wired  in series.
#10 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2513 posts
Posted 21 January 2014 - 11:28 AM
Look at the strat wiring diagram above.  The pickups can only be wired in parallel.  The shields are all tied together.
#11 rublalup
rublalup
    Iknowathingortwo
  • PipPip
  • 157 posts
Posted 21 January 2014 - 11:35 AM
ím sorry i´m talking about humbuckers...
#12 alexisltd
alexisltd
  • 53 posts
Posted 21 January 2014 - 05:06 PM
ok...the 2 coils in a humbucker pickup are generally connected in series
#13 mabbaticchio
mabbaticchio
  • 52 posts
  • Registered Products:3
Posted 22 January 2014 - 11:30 AM
The BM pickups are wired in series.  This allows you to combine single coil pickups to act like a humbucker.  Brian uses a treble boaster because he uses the normal channel of the Vox AC30 which is dark sounding on it's own.  I used to own this guitar and agree it is a bit dark sounding unless you play single pickups on their own as opposed to multiple pickups in series.  It is also a very unique sounding instrument and can get close to Brian's sound.  As far as your treble boaster, try using the boost eq.
#14 joakey
joakey
  • 4 posts
Posted 22 January 2014 - 12:53 PM
Yes, sorry, I meant that the pickups are wired in series - I just got a bit mixed up.  :rolleyes:
Thanks for all the suggestions, I will have a play with that!
Also tagged with one or more of these keywords: treble booster, hd500x
