Gearbox Is Dead, What A Shame.
gearbox
47 replies to this topic
#1 GregTBD
GregTBD
  • 6 posts
  • LocationSwitzerland
  • Registered Products:9
Posted 22 January 2014 - 08:39 AM
Hi.
I always use GearBox for edition on POD X3 PRO, it was so simple for moving presets from places to places, interchange  them and copying, editing, save and restore.
But now with the newest driver 7.3.6. GearBox & PODX3PRO won't never work together. I've read on the website that
GearBox is no longer available. Can't believe that, it is the best app. for me.
Have you explanations, or everything else to replace this app. I try to go back with an old driver but I can't do...
Hope you can help me, or Line6 please to update GearBox.
Greg.
  • 1
#2 BigChas52
BigChas52
    Guru
  • Line 6 Expert
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 22 January 2014 - 09:00 AM
Gearbox downloads are still available.  go to http://line6.com/software   Select "Gearbox" and -All OS-  If you need an older version, you may need to check the "Archive" box
#3 GregTBD
GregTBD
  • 6 posts
Posted 22 January 2014 - 09:40 AM
Yes, GearBox 3.72 still in that page, but doesn't work with new driver 7.3.6. in my POD.
At this address, you can read no longer made... : http://line6.com/legacy/gearbox.
I don't know how to reinstall an older driver in the POD.
Thanks for your help. Best regards. Greg.
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 22 January 2014 - 10:36 AM
the legacy page is in regards to the gearbox plugin....
the gearbox editor is still viable... although updates are highly unlikely... it should work.
i suspect that you are using a mac from the driver number... i could be wrong....
if thats the case it needs to be an intel mac.
if thats the case, i'd contact support, they can probably walk you through this easily.
#5 GregTBD
GregTBD
  • 6 posts
Posted 23 January 2014 - 05:22 AM
Yes right.
I use a MacBook Pro, intel, with OSX 10.9.1. GearBox 3.72. Driver 7.3.6.
When opening GearBox, a message about a non-correct driver.
When I go far, GearBox download the data from the POD X3 PRO, but no amp appear in the "GearBox" window
and when I click on a Tone in the "Hardware Memory Window" it disappear immediately.
#6 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
Posted 23 January 2014 - 05:50 AM
this worked for another guy on the forum:
To remove driver 7.3.6
1- On a terminal run this command   sudo pkgutil --forget com.line6.driver.xtaudio.package (enter)
2- Then this sudo pkgutil --forget com.line6.driver.xtmidi.package (enter)
3- Reboot
To install driver 7.2.9
4- Downloaded driver version 7.2.9  http://line6.com/sof...a.html?rid=5675
5- Run the 7.2.9 driver package to install it and ended the process with a reboot
Yes right.
#7 GregTBD
GregTBD
  • 6 posts
Posted 23 January 2014 - 07:00 AM
Will try, this...
Thanks.
#8 GregTBD
GregTBD
  • 6 posts
Posted 25 January 2014 - 12:10 AM
Hi.
It works again with "X3 PRO & X3 Live too" not 100% but OK for setlist édition.
Thanks a lot for saving me.
Best regards.
Greg D.
#9 mwatling
mwatling
  • 8 posts
  • Registered Products:4
Posted 11 March 2014 - 01:16 AM
Hi All,
Having the same problem, tried the link to the driver above which I assumed by the post was for Pod X3 Live, and it takes me to the StageScape M20d drivers.... Please help, what am I missing....?
Many thanks.
Mark.
#10 mwatling
mwatling
  • 8 posts
Posted 11 March 2014 - 04:40 AM
Hi, couldn't find the 7.2.9 drivers but did find 7.2.4 drivers which I can confirm also work!
M
#11 bvanhoeck
bvanhoeck
  • 6 posts
  • LocationBelgium
  • Registered Products:5
Posted 23 March 2014 - 09:40 AM
The trick to solve the problem is easy :
Uninstall the driver version 7.3.6 with the utility found in the Line 6 folder : Line 6 Driver Uninstaller
Reinstall the driver version 7.2.9. This solves the problem.
This older driver can be found on he Line 6 website.
Why doesn't Line 6 work on an update of driver version 7.3.6. It's a shame.
  • 2
#12 chvchris
chvchris
  • 10 posts
Posted 24 April 2014 - 08:25 PM
I am VERY disappointed and depressed about line6 support. I've been a POD user for a decade, having changed POD 2, xt, X3....
I can't believe this is the kind of support for thousands of people owning MACs (as the majority in audio engineering does). I am trying to find some kind of software that works for backing up patches, changing names, or searching through cabs and preamps. Unfortunately Gearbox needs a "hack" to work on the latest MAC OS X with the latest driver provided by Line6 themselves. This is really a shame for a company that has been trusted for many generations of PODs among musicians.
Another thing is that Gearbox seems last updated...
Line6, really?
  • 3
#13 BadHouses
BadHouses
  • 43 posts
Posted 24 November 2014 - 07:49 PM
If you downgrade driver, you'll get kernal panics on usb removal or x3 switchoff.....  Restarting your mac and losing work each time it happens accidentally....
I upgraded my mac (old one was PPC - not supported after a while!) in order to sort these problems out!  lol!
I have requested that they open-source retired software, I suggest guys you do the same.
#14 BillBee
BillBee
    Power User
  • PipPipPipPip
  • 2390 posts
  • LocationMichigan
  • Registered Products:8
Posted 25 November 2014 - 04:19 AM
Not a Mac dude myself, but I support open source software and that is a good idea though I don't know how much proprietary code would be in Gearbox that L6 would want out there. IMO it is a competitive market and the editors can be a big tipping point in sales.
-B
Smell the glove.
#15 BadHouses
BadHouses
  • 43 posts
Posted 26 November 2014 - 01:00 AM
-B
True-ish.
If the software is retired it costs us money in upgrades, on something that technically speaking only needs to be replaced because of a few software compiler flags.
#16 BillBee
BillBee
    Power User
  • PipPipPipPip
  • 2390 posts
  • LocationMichigan
Posted 26 November 2014 - 03:44 AM
Still it could be worth a shot suggesting it.
This is where you would do it: http://line6.ideascale.com/
Would be cool if it was revamped a bit :)
-B
  • 1
Smell the glove.
#17 BadHouses
BadHouses
  • 43 posts
Posted 26 November 2014 - 02:28 PM
http://line6.ideasca...re/677387-23508
  • 1
#18 BillBee
BillBee
    Power User
  • PipPipPipPip
  • 2390 posts
  • LocationMichigan
Posted 26 November 2014 - 06:16 PM
Cool my man,
I'll go check it out and give you a vote tomorrow!
Edit: Done - hopefully L6 Legal won't be running around the office sputtering and muttering too much :)
-B
Smell the glove.
#19 BadHouses
BadHouses
  • 43 posts
Posted 26 November 2014 - 10:25 PM
Cool my man,
-B
I'm looking into hacking the mac installer scripts and some contents.  I got gearbox to run on yosemite, but it just tells me that the x3 is using an incomnpatible driver and will be ignored.  It gets singled out once recognised, so i'll start with that tomorrow.
#20 deankobayashi
deankobayashi
  • 11 posts
Posted 07 December 2014 - 11:09 AM
There is a discussion on another string regarding Gearbox. The string started because X3 was causing the Mac to crash when plugged in using USB. Then the discussion morphed to people complaining that Gearbox isn't being supported.
I started looking on other strings to see if there are others and I see that there are.
Line 6 has chimed in to say that there are no plans to update Gearbox but I sure hope they do. I got the X3 because it has all the bass amp/cab models. L6 doesn't make anything for bass players any more and I believe that it's a financial decision as they probably found that marketing to the guitar market is much more profitable than the bass market. Since they don't work in the bass arena anymore I hope they will put a little bit of time into updating Grearbox for some goodwill as I see that they have left many players in a tough position by not supporting the software that many of us use with our X3.
Just my thoughts...
  • 1
#21 BadHouses
BadHouses
  • 43 posts
Posted 16 December 2014 - 02:32 PM
Just my thoughts...
Go to Digitech..... (BP 355 is what you're after, a third of the price of the original cost of the X3L)
#22 ctgblue
ctgblue
  • 4 posts
  • LocationMid Atlantic Coast
Posted 21 December 2014 - 04:47 PM
Unfortunately, now gearbox is not even available as a download. I was using Gearbox this morning, ran line 6 monkey and did the suggested upgrades, now gearbox won't recognize my DI Gold at all, or if it does, none of the upgraded model packs.
There's got to be something that can be done when you can't use what worked yesterday, because of their suggested updates?
Before you criticize someone, walk a mile in their shoes
THEN, you're a mile away, AND, you have their shoes
Mod at BB.com
#23 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
Posted 21 December 2014 - 04:53 PM
gearbox is still available and as far as i know, still working on all windows computers...
true gearbox is no longer supported or updated...
the only issue that i know that makes gearbox not work is an apple update called Yosemite....
if that doesn't apply to you... then the issue is probably something else.
#24 Rockinguy
Rockinguy
  • 37 posts
  • Registered Products:3
Posted 25 December 2014 - 03:52 PM
I'm also upset that Line6 basically left their Guitarport/Gearbox units to die. Gearbox was and is the best damn software out there. I can't find a replacement and I know someday I'll need to. The functionality of that software is incredible. Nobody even includes mp3 players with their software any more. Gearbox has the mp3 player, section looper, half speed w/o pitch change. Just a shame they left it to die and everything with it. When mine quits working that's where Line6 and I part ways.
#25 BloodWorkStudio
BloodWorkStudio
  • 13 posts
Posted 27 December 2014 - 10:25 PM
I tried the solution from "TheRealZap" and the file will not let me install on my HD. The error is "The software requires MAC OS X 10.6 or above" I have 10.10.1.
Any suggestions?
#26 uslimey
uslimey
  • 6 posts
Posted 29 December 2014 - 11:07 PM
GEARBOX IS ALIVE AGAIN!
So I got the Gearbox partially working on Yosemite yesterday... Today I think I managed to get it working all the way.
The solution is a follows:
  • Download and open Gearbox 3.72.dmg
  • Right click the GearBox.mpkg icon
  • Left click 'Show Package Contents'
  • Double click 'Contents' folder
  • Double click 'Packages' folder
  • You should now see 10 individual packages... Install each one
Note: If you previously installed Monkey with a newer driver, it will not allow you to install the drivers in this package... You will need to uninstall the newer drivers first, then you should be good to go. Search the forum for details on how to uninstall the drivers using command prompt. Someone else posted instructions on how to do this... They also suggested another driver to use... I tried to install that one first and it wouldn't let me, so I ended up installing the drivers from the from the GearBox package above...
Anyway, I am running Yosemite 10.10.1 on a MacBook Pro Retina, with a POD X3 Live, and so far it is working fine... No panic attacks... I was able to create and upload a tone to one of my user presets...
By the way, before this, I did update the firmware on the X3 using a a separate version of Monkey that I had downloaded previously. I am not sure is this have any relevance with regard to MAC and the X3 playing nicely together once I reinstalled the old drivers.
  • -1
#27 BloodWorkStudio
BloodWorkStudio
  • 13 posts
Posted 01 January 2015 - 06:56 PM
^ worked for me! Thanks uslimey!
#28 ctgblue
ctgblue
  • 4 posts
Posted 23 January 2015 - 04:52 AM
 apparently, there is no longer a download
GearBox                          - All software -                                  GearBox                          - All OS -                                        - All OS -
GO Beta  Archived
At this time, there is no  archived software available that matches your selection.
fortunately, I still had an old DL on backup, but it's not cool to not still have the software DL for those of us with Gearbox DI Gold etc.. with ALL THE MODELS
Mod at BB.com
#29 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
Posted 23 January 2015 - 05:55 AM
Final versions are still freely available for download...
Windows download: http://line6.com/sof...a.html?rid=3121
Mac Download: http://line6.com/sof...a.html?rid=3120
not sure where you are going wrong.
GO Beta  Archived
#30 venom5150
venom5150
  • 6 posts
Posted 23 January 2015 - 04:19 PM
Line 6 has succesfully turned me against music. I'm done with everything related to music now. I even hate listening to it.
  • -1
#31 CC51
CC51
  • 52 posts
Posted 05 March 2015 - 12:28 PM
I hope GearBox lives forever.....why L6 has to rename it and constantly ignore it at times is a mystery, as its probably the strongest positive Ive read about Line 6....strange how businesses works sometimes?
I guess reinventing yourself is required of all businesses, but is it that hard to keep something alive thats a foundation for a lot of happy customers, who then spread the word all over?
I hope they maintain some type of free download of GEar Box, in addition to creating great new stuff.
I was happy when I plugged in my X3Pro and kabooom!! theres my GearBox!!!! very good.
#32 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
Posted 05 March 2015 - 12:38 PM
its available and its fine for most users....
it just simply wont be updated any more...
not going away... just at the is what it is point in its life....
its never been renamed or anything like what you suggest... there are just other programs available.
  • 1
#33 GeoffD
GeoffD
  • 9 posts
Posted 29 March 2015 - 10:26 AM
I've just changed from a PC to a Mac running Yeosmite and I can't get gearbox to work with my POD X3. As I'm new to Macs could someone run through how to get the software to work. I've installed Monkey 1.68 which found the POD, but no Gearbox. Do I have to uninstall monkey? Help!
#34 madmax559
madmax559
  • 10 posts
Posted 30 October 2015 - 09:02 AM
I understand that products do get old at some point
Telling a customer that has spent nearly a $1000 on Pod X3 Pro &  Floorboard II  that theres no way to edit a patch on their pc/mac is like pissing on your paying customers
It doesn't cost much to recompile a code base (I am a programmer) especially when the code in question makes use of open source libraries
PNGLib. ZLib. etc etc  (GearBox About.....)  . Open source the editor so people can maintain it.
Or just document the api calls so people can get/set data to/from a pod unit.
Or make their editor modular with plugins to support old & upcoming units
I had considered looking at the Helix but after 2 bad experiences in a row with Line 6, I would not consider buying their products.
Its ironic that I get more support from Digitech on a used 2120 unit that I bought back in 2004 ...now thats customer service...
...and I'm not even a professional musician....just an average guy who like to play guitar once in a while..
  • 2
#35 domisilafa
domisilafa
  • 2 posts
Posted 06 December 2015 - 11:52 AM
Does anybody have the zip file or a download link for Gearbox 'Real Name amps' patch? Because all the link is dead  :wacko:  :wacko:
#36 rawhead
rawhead
  • 1 posts
Posted 18 March 2016 - 09:59 AM
Line6, really?
Yeah it sucks. I have also Live XT for about ten year. Works great, solid as rock, hardware done great, but software support sucks. WHY!?
#37 BillBee
BillBee
    Power User
  • PipPipPipPip
  • 2390 posts
  • LocationMichigan
Posted 18 March 2016 - 10:23 AM
That's a better question for M-Soft and Apple. L6 didn't change their code they did - each OS has limited legacy support.
Smell the glove.
#38 Skipernicus
Skipernicus
  • 8 posts
Posted 18 April 2016 - 07:17 PM
You know, Apple didn't sell me the music gear. And if we could go backwards in system updates, I bet most of us would. I certainly would. These little invisible system "improvements" break our gear.
In the meantime, we've been legacy-ed to death. Funny, my Korg A3 (from the early 90s) still works fine...
At all events GRRRR! I didn't rent this gear, I bought it!
#39 Springstone
Springstone
  • 1 posts
Posted 14 June 2016 - 11:40 AM
Wow. Like others, I'm horrified at the lack of love for loyal customers. Sorry but making any comments about the world moving on, aka OS vendors updating their operating systems is just stupid.
At the end of the day, Line6 has decided to stop supporting their product. Probably because they want you to buy their new product, and this is their strategy. What you buy today will be supported for a year, and then you need to buy the next version.
While the product still works (in my case a POD X3 Live), I can't edit it any more easily - I miss GearBox... which just boggles my mind. Why can't I save POD Farm patches to my X3? It's what, a couple of lines of code to enable this? Sure kill off Gearbox, which btw was awesome, but replace it with nothing???  My pain is that I want a solution... bake it into one of your supported and developed products if you're adamant to kill of GearBox...
Please come up with a sensible solution.
#40 floaguzin
floaguzin
  • 1 posts
Posted 01 August 2016 - 05:40 PM
I have the x3 live too. I can't believe it. Anywhere i can find gearbox???
Also tagged with one or more of these keywords: gearbox
