Volume Pedal Position Won't Stay At 100% - Xt Live
3 replies to this topic
#1 claudio311
claudio311
  • 2 posts
  • Registered Products:1
Posted 19 May 2013 - 08:00 AM
Max volume pedal position won't stay at 100%. Followed the pedal calibration steps and this solves it only briefly.
After playing for about 5 - 10 minutes there's a sudden volume drop.
Scroll down the edit menu to the volume position and the max (toe all the way forward) has decreased to around 70%.
Recalibrate pedal and it's fine for another 10 minutes then it happens again and so on.
All monkey drivers are up to date. Should I try flashing the firmware? Does anyone have any ideas how to fix this?
I know it's an old pedal but apart from this and a strange buzzing noise (not sure if I should bring that up here or make another thread?) it's been going well.
Really appreciate any help, thanks in advance.
#2 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 19 May 2013 - 09:23 AM
http://line6.com/sup...age/13316#13316 i read some threads in the previous forum. i believe you might have to have it serviced. but read trough them and see if you can get anything. there is a area on the thread page that links to similar threads on the right towards the top
  • 1
I'M SO HAPPY!
#3 claudio311
claudio311
  • 2 posts
Posted 19 May 2013 - 05:34 PM
Thanks Toneman.
I should have searched more thoroughly before posting a similar problem. Sorry about that.
Forgot to mention that to stop the volume fluctuating, I've increased the min pedal position in the edit menu to 100%.
This stops it jumping between volume levels but now I can't use the volume pedal and the wah still has a restricted range, doesn't fix the problem but allows you to use it at a constant full level.
Looks like I might need to replace the pedal circuit board. Not sure how to get a hold of one though.
I'll try the solutions offered in that thread when I can and post back results.
Thanks again Toneman, cool dog.
#4 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 19 May 2013 - 05:47 PM
Thanks Toneman.
that stuff is in the old forum. i had a little trouble finding stuff before i knew where to look. the best thing to do is call them about the board. s'all good ;)
I'M SO HAPPY!
