Suggestions For Big Wall Of Sound! Pod Hd Desktop
sound metal pod hd desktop
6 replies to this topic
#1 robmlisanti
robmlisanti
  • 31 posts
  • LocationNew York
  • Registered Products:2
Posted 23 January 2014 - 09:05 AM
Any suggestions on how I can get a BIG sound with my POD HD desktop
2 amps?
Mixer settings?
Chorus effects?
etc....
Thanks!
#2 duncann
duncann
    Guru
  • PipPipPipPipPip
  • 2862 posts
  • LocationWI
Posted 23 January 2014 - 12:51 PM
Here's a preset that's for the HD500 that might be something of what you're looking for.
#3 brian6string
brian6string
  • 81 posts
  • Registered Products:1
Posted 23 January 2014 - 06:32 PM
One way is to take the same amp model x2. Mix both to the center, but use different mic combinations on each. My favorite is SM57, one on-axis, one off-axis.
Another way is to mix and match one clean-ish amp with one more distorted, hard pan these L-R. Suggest AC30 + Dual Rectifier. For this arrangement, I put a digital delay in one of the signal paths, 100% wet with a very short delay time (24ms or so). Gives you a little bit of separation between the two signals.
  • 1
#4 StephenSLR
StephenSLR
    Iknowathingortwo
  • PipPip
  • 252 posts
  • LocationSydney, Australia
Posted 27 January 2014 - 06:00 PM
Can you describe what's in that preset?
s
Listen to my band here:
#5 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 322 posts
Posted 28 January 2014 - 12:16 AM
Most big sounds come from doubling or quad tracking the guitars. Are you doing that?
  • 1
#6 GTLazer
GTLazer
    Iknowathingortwo
  • PipPip
  • 215 posts
Posted 28 January 2014 - 01:45 AM
I've had better results from 2 of the same amp with 2 different cabs, rather than two different amps, although obviously ymmv.
As ever, meambobbo's guide contains a wealth of information on the subject.
You like my answer? Hit the up arrow. You no like my answer? Hit the down arrow. Sorted.
#7 duncann
duncann
    Guru
  • PipPipPipPipPip
  • 2862 posts
  • LocationWI
Posted 28 January 2014 - 04:37 AM
Here's what's in the preset.
FX, Amp Amp Parameter, Amp Cab Parameters, Mixer:
Also tagged with one or more of these keywords: sound, metal, pod, hd, desktop
