Using Pod Farm With Pod X3 Live
3 replies to this topic
#1 akaiyang
akaiyang
  • 4 posts
  • Registered Products:3
Posted 19 May 2013 - 10:11 AM
Hi Guys,
I really need some help. Basically, I am looking to use the POD farm via the  POD X3 Live. i.e.
1.  I am currently using the following but cannot figure out how to monitor real time using the tones from Pod farmi.e. Guitar Input  >>>> POD X3 Live >>>>> USB Cable to Compute >>>> POd Farm >>> ???
So I want to use the a setup by bypassing the tones from POD X3 Live and using it only as an audio interface. I want to be able to use MONITORING from Pod Farm and use the tone from POD Farm to record. Basically, in real time and not in post processing....I am looking for the following setup:
Guitar Input > POD X3 Live only as audio interface > USB Cable to Computer >Pod Farm > Real time play and  recording with
        Pod Farm. And, monitoring with
        tones from Pod Farm.
Can I use POD X3 with Pod farm in real time play? or can it only be used in post processing i.e. recording the dry signal and then using the plugin. I want to be able to create the tone on Pod farm by playing it in realtime.
Please let me know.
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17846 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 19 May 2013 - 11:19 AM
pod farm plugin, is really too latent for realtime
just record the dry and the wet, and make tweaks in post.
its the same tone capability either way so why complicate it?
#3 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 19 May 2013 - 05:53 PM
Since the POD Farm plug-in has the same amps and effects as the X3, you could tweak on the X3 live, and record the dry signal via the ASIO sends.  I would also record the wet signal on a separate track as a reference, but leave it out of your final mix.
Once you have it dialed in, make a note of your X3 settings and use the POD Farm plug-in to recreate them on the dry track.
There may also be a way to use the X3 as an input device for the POD Farm 2 stand-alone program, but since it's been a while since I've owned an X3, I don't recall how to do that.  The methodology there, would be to tweak in PF2 and save the settings.  They could then be opened in the POD Farm 2 plug in.
In either case, the POD Farm 2 plug-in is not for live play, or first takes.  It is an effect to be added in post production.
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16056 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 20 May 2013 - 05:45 PM
or can it only be used in post processing i.e. recording the dry signal and then using the plugin....
  You can even use Gearbox to save the preset from the X3 to the Pod Farm preset folder on your computer. That way you can call up the X3 preset in Pod Farm without having to recreate settings.
  • 1
.... John Lennon
