Multi Stomps In One Preset
stomp efx
4 replies to this topic
#1 gigid
gigid
  • 2 posts
Posted 19 May 2013 - 12:08 PM
Hi
I would like to know if is possible to use more then one effect at the same time
thanks
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17756 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 19 May 2013 - 04:46 PM
i think the answers no, unless you have a pod HD, but what device do you have? someone may be able to give you a better answer based on that info.
#3 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 19 May 2013 - 05:39 PM
The Line 6 devices have always been able to use multiple effects, but not two of the same type in the same preset.  For example, you couldn't use two distortions, or two delays in the same preset.
This has changed with the POD HD series, and POD Farm 2.  You can have multiple effects of the same type in the signal chain.
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17756 posts
Posted 19 May 2013 - 06:05 PM
couldnt tell from the question if he just wanted to activate or deactive them with a single stomp....
#5 Orphan2112
Orphan2112
  • 6 posts
Posted 03 June 2013 - 06:09 AM
I was hunting around and i found this:-
"Here's a nice workaround that can help you achieve something that you might have missed otherwise. Normally you can assign one modulation effect with your POD XT- or Gearbox- series gear. However there's a way of using two modulation effects at once. Thanks go out to Crusty Old Rocker for sharing it through Vettaville.nl. Here's his complete story.
"I stumbled across a neat little work around. I needed a tremolo (tremolo effects are in the modulation effects category) combined with a chorus (which is also in the modulation effects category) so I can't have tremolo and chorus together. Right? Wrong!!!
I remembered that the Electro-Harmonix Memory Man is a combination of delay and chorus. So I set up the Opto-Trem and added the Analog w/Mod to it. Now I just needed to get rid of the delay. I turned the delay time to minimum and feedback to zero so all I'm left with is the chorus.Now, before you jump in to tell me that the chorus of the Analog w/Mod is only applied to the echo and not the direct sound, I'd like you to try this yourself.
Turn off any modulation effects and just turn on the delay and select Analog w/Mod. Wind the delay time right down to minimum (20ms), turn the feedback to zero and here's the important part, set the Mix to 50% less or more than 50% reduces the amount of chorus. Now adjust the Mod Speed and Depth of your chorus to suit your taste. By the way, this same trick can be applied to the Phase Echo to add a phaser effect to another modulation effect.
Now just add a modulation effect from the Modulation category and there you have it, a chorus or phaser that you can add to any other Modulation effect.
I don't know if others have discovered this workaround before me but I just thought that it is worth sharing." We've added the tremolo/chorus patch for your convenience.
It can also add some depth to the "rotary speaker + horn" effect... essentially modding a mod:) It's not up there with B4 or anything, but it makes it usable. Drive--->Rotary w/mod--->mod delay(no delay)--->Eq. If you need a more stereo patch...put the mod delay first.
The full thread can be read here -> http://line6.com/sup...ve/thread/47097
Peace
