keneds Posted January 25, 2014 Share Posted January 25, 2014 Curious if i'm doing something wrong......When working with Spider Edit, I have the usb connected to my FBV Express pedal into my computer and the cat5 cable connected from the amp to the pedal,,,,,When i start the edit program it always tells me "No Line 6 device connected" It takes me quite a few open and closing of the program before it detects my amp. Is there something i'm not doing right? Thanks, Ken Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted January 29, 2014 Share Posted January 29, 2014 Try connecting the FBV first (no CAT5 cable connected to amp), call up Spider Edit, then connect the amp. Quote Link to comment Share on other sites More sharing options...
Stemar219 Posted January 29, 2014 Share Posted January 29, 2014 I have a spider 75 amp and a PODHD500x. what is the best way to connect them. I would like to use the effect from the POD but it seem that the POD is acting like a pre-amp. Any idea's on the best way to get the most from the set-up? Quote Link to comment Share on other sites More sharing options...
a_deppe Posted January 30, 2014 Share Posted January 30, 2014 What OS you are using? If it is a mac you need to be logged in as admin - otherwise it would work... Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted February 1, 2014 Share Posted February 1, 2014 I have a spider 75 amp and a PODHD500x. what is the best way to connect them. I would like to use the effect from the POD but it seem that the POD is acting like a pre-amp. Any idea's on the best way to get the most from the set-up? You'll do better starting your own thread than posting in an unrelated thread. I 2 ways to use the Pod with the Spider: 1) Guitar > Pod line out > Spider guitar input. Keep the Spider on Clean setting 2) Guitar > Pod line out > Spider CD/MP3 input. This bypasses the Spider preamp/FX section Quote Link to comment Share on other sites More sharing options...
keneds Posted February 2, 2014 Author Share Posted February 2, 2014 What OS you are using? If it is a mac you need to be logged in as admin - otherwise it would work... I don't use a Mac, but I "ran as administrator" and it worked, I also switched my usb cable. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
Tommytater Posted March 15, 2014 Share Posted March 15, 2014 Running it on a mac. OS X Version 10.9.2 No matter what combo of connecting and starting up Spider Edit it says no line 6 device connected. Spider IV 75 Amp FBV Express MKII Tried different cables. I used the cables to run my printer and it works so cables not the issue. Kinda frustrated. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted March 17, 2014 Share Posted March 17, 2014 The following usually works in Windows, I dont' know about Macs. Uninstall Spider Edit and any other Line 6 software you have loaded up, including Monkey. Delete the folder titled 'Line 6' in your program files - it still contains the uninstlaled Line 6 programs files. Re-download Monkee, then use it to to reinstall Spider Edit. 1 Quote Link to comment Share on other sites More sharing options...
