Xt Live Into Effects Loop Of Marshall Vst 100
live sound using xt live
3 replies to this topic
#1 nenic
nenic
  • 4 posts
  • Locationmanchester uk
Posted 20 May 2013 - 05:00 AM
is it best to go guitar, xt ,amp or to go through effects loop for live performance.marshall valvestate 100 watt.thanks in advance.
#2 epiphany1415
epiphany1415
  • 6 posts
  • Registered Products:2
Posted 13 July 2013 - 10:22 AM
My advice is to go Guitar>Amp>FX Send>POD Input then POD output>FX return.   This (in my opinion) the best setup for amps as far as keeping the inegrity of the signal.  When I run the guitar straight into the POD and then into the amp, I lose integrity.  In other words, when I switch on my distortion, it loses a lot of gain, even if/when I can get my clean channel to sound almost identical.  The only problem is if your amp doesn't have a footswitchable FX loop button.  Surprisingly, many amps don't, but if your amp does, go with the FX loop.  If you DO go with the FX loop, make sure to check the rear panel of your POD (the panel with all the input/output jacks) and set the "Amp/Line" switch to "Line."  This will give you the purest tone (in my opinion) as it switches the POD to "studio direct mode," which bypasses the POD's preamps and only adds on the effects you assign.  I hope this helps!
Also, I would like to add that I'm playing through an Egnater Vengeance, which is a pretty high quality amp, so the scenario could be 100% using a Marshall Valvestate.  If you try my recommendation and aren't satisfied with it, please don't think any lesser of me, it's just what I've found that works for me! :)
#3 laudani
laudani
  • 2 posts
  • Registered Products:1
Posted 05 July 2016 - 06:18 PM
Hi epiphany1415, I'm using this configurarion:
Guitar>POD Input then POD output>FX return
do you think this is a good setup to keeping the integrity of the signal?
#4 BillBee
BillBee
    Power User
  • PipPipPipPip
  • 2421 posts
  • LocationMichigan
  • Registered Products:8
Posted 06 July 2016 - 09:52 AM
Necro thread! \m/
Hey there, I have a VS100 head and have ran the XT Live the same way, it does sound great through a closed back 2x12. Run Studio Direct then try the other output modes to see what gets you close to what you like. Fine tune with the EQ.
Its a Valvestate that you want to run an XTL into - what kind of integrity are you hoping to save? Yes, the VS can sound good if a decent guitar w/decent pickups is played decently into it. Plugging an XTL "can" sound great "if" you put the time in and build some quality patches.
Tip: Customtone is not the solution - learn to build your own tones.
-B
Smell the glove.
