Ipad Mini For Mobile Pod And Garageband Simulataneously?
sonic port garageband audiobus ipad mini
2 replies to this topic
#1 Sumatra_Gold
Sumatra_Gold
  • 49 posts
  • Registered Products:1
Posted 27 January 2014 - 06:09 AM
Was recently given an iPhone 4 for Christmas. I found out that the device was compatible with Sonic Port and since GarageBand was included on the phone and Mobile POD was a free DL, I went ahead and pulled the trigger on the Sonic Port. I also purchased Audiobus, so I could use both apps (GarageBand and Mobile POD) at the same time. That is what started this whole problem which I'll get to next: To my horror, I discovered that Apple doesn't support using these apps at the same time on iPhone 4, rendering the marriage of Mobile POD and GarageBand null and void. You can use one...or the other, but you cannot use Mobile POD and GarageBand as a couple, which really, really sucks, since GarageBand's guitar rigs are among the fizziest, processed, crapola sounding amp models on planet earth. What to do?
I've been looking for an iPhone 4S on the cheap, since its chip set is supported with these apps by Apple, but haven't had any luck yet. So that's one option. The other would be to get an iPAD mini, which has a much bigger display, and at my age, a more readable display is a plus. Here's my question: does the iPAD mini support using the AudioBus app to marry Mobile POD and GarageBand?
Other than that, if anyone has other suggestions, I'm all ears. Thanks.
#2 RNRage
RNRage
    Iknowathingortwo
  • PipPip
  • 148 posts
  • Registered Products:2
Posted 17 February 2014 - 08:34 AM
Bump.
I'm interested in knowing as we'll.
Sent from my iPad.
Endorses:
Amps: Mesa Boogie, Fender, Blackheart, Line 6
Guitars: Fender, Gibson, Epiphone, Takamine
Effects: Line 6, Boss, MXR, DOD, Ibanez, Crafter, Mesa Boogie, Heil, Morley
#3 cruisinon2
cruisinon2
    Uber Guru
  • 5155 posts
  • Registered Products:5
Posted 17 February 2014 - 11:31 AM
Can't say for sure it it'll work with the Mini, but it does work with my 5th gen. iPod. Some of the tones are great, but the battery life when running even just Mobile POD and Sonic Port is LAUGHABLE. Get's even worse with garage band going at the same time. Now I'm sure that the iPad mini has a larger battery than the iPod 5, but I don't know by how much.  From fully charged, I can drain it dead in less than 2 hours, and the iPod is only a few months old, and doesn't get used all that much. It's also kinda ridiculous that Mobile POD can't run in the background, so you're not forced to have the screen on all the time, which is any device's biggest battery drain. So don't be too upset that it ain't working with your phone...I suspect the iPhone battery is of similar capacity, if not the same as the iPod. iPad Mini results might be a little better, I suppose.
It's a great idea, but the Sonic Port really needs it's own power supply. Relying on the iOS device is simpler, but not terribly practical...and they sell this thing as a gigging tool as well as recording. As long as you don't mind charging your iWhatever between sets I guess...but as a all-in-one DAW/amp/interface, it doesn't really work, unless you don't mind stopping your gig/ recording session in the middle because you ran out of juice.
Also tagged with one or more of these keywords: sonic port, garageband, audiobus, ipad mini
