Dt Cabinet Simulated Direct Out Questions
dt xlr recording direct out cab sim pod hd pa
31 replies to this topic
#1 radatats
radatats
    Power User
  • PipPipPipPip
  • 1035 posts
  • LocationOrange County, NY
Posted 28 January 2014 - 07:47 PM
The XLR out on the DT provides a transformer tapped direct out with cabinet simulation.
Here are some questions I have, maybe someone can answer them...
- does transformer tapped mean they are pulling the same audio that is going to the speaker including power section distortion just at a much lower level straight from the output transformer?
- how is cab sim applied?  Does that signal then go back into the DT for processing to add the cab sim?
- if I am already using cab sims with my amp/preamp modeling, why would I want another cab sim applied to the output here?
- if it is the same type of cab sim as with the amp/pre, what cab are they using?  what mic are they using?
- is it linked to the internal amp models stored or to the one being used from the POD?
- can the cab sim be adjusted or changed with an external editor in any way?
#2 MartinDorr
MartinDorr
    Iknowathingortwo
  • PipPip
  • 236 posts
  • LocationArizona, U.S.A.
Posted 29 January 2014 - 10:24 AM
I don't think I have solid answers, but I can describe my view of how it may work ... (I have not done any of it)
  1. I don't know what transformer tapped really means, except that it is supposed to emulate power amp tone characteristics on the DT XLR out. I think there is no crisper definition of what it actually does within the DT to achieve this.
  2. Cab sim within the DT is most likely done by the DSP and due to cost of additional AD/DA conversion of a transformer tapped analog signal it will most likely be done before the DA conversion of the signal fed to the power amp section (similar to how reverb in the DT is handled, i,e., before the effect loop out (again to save a DA/AD conversion)). Best case scenario would be if there are 2 DAs after a split of the digital signal path: One going to power amp section and the other going to a DSP cab/mic sim stage before being converted to analog for XLR out. Whether the 'transformer tapping' ends up getting mixed in by the DSP (would required some AD of transformer tapped signal) or in the analog domain is an open question.
  3. Cab / Mic sim is just just a form of EQ / compression combo characterized for a specific Cab/Mic selection. Use it if you like the effect. Even Line 6 seems to have opted for turning Cab sim on in the DT preamp section even though they clearly send the output primarily to the DT speakers. Obviously they could play some more tricks in the DT to compensate for the DT speaker. Would be hard to verify, I think.
  4. Don't know what they did before the latest DT FW update. Now I believe they describe it in the DT MIDI specification, but I did not recheck.
  5. The Cab sim selected in the HD is done by the HD DSP; the cab sim in the DT for the XLR out is done in the DT DSP, I think. They could be aware of each other, but there is no documentation saying so as far as I know.
  6. There are DT MIDI editor SW programs (search forum, i don't recall details) and you can use any generic MIDI control surface/device to control the Cab/Mic setting for the 8 program slots in the DT (once they are programmed the Type sector on the DT is used to select the program (together with the amp type) on channels A and B.
#3 radatats
radatats
    Power User
  • PipPipPipPip
  • 1035 posts
Posted 29 January 2014 - 12:19 PM
thanks but none of those actually answer the questions.  Unfortunately there is no documentation of this feature and there are a lot of issues with the XLR out from the DT.  I appreciate your input though...
#4 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 5548 posts
  • LocationMinneapolis, MN
Posted 29 January 2014 - 12:27 PM
Essentially, yes. So what it means is that it's not simply the preamp signal with cab emulation. You get the power amp interaction as well.
Yes, the cab emulation is added post this signal.
It's my understanding that if you're connected to the POD via L6Link, the cab simulation will be the same as whatever you have in the preset on the POD.
I don't believe so. The DEP control in the POD don't effect this simulation as far as I know.
Time is a train
Makes the future the past
Leaves you standing in the station
Your face pressed up against the glass
#5 radatats
radatats
    Power User
  • PipPipPipPip
  • 1035 posts
Posted 29 January 2014 - 02:00 PM
thanks Phil, kind of what I suspected but just not really diggin why they do it this way.  I start with a digital modeled amp and cab, send it through an analog tube amp and then back into the digits to get a second cab makeover and back AGAIN to a usable audio signal to the board...  so I guess the DT knows what cab setting I have in the POD and then uses the same cab/mic config in the DT to process my signal a second time...  Wow...  so what happens if I have no cab selected in the POD? Hmmmm...  Why can't it just go from the transformer tap to the XLR without another digital makeover?
#6 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 5548 posts
Posted 29 January 2014 - 02:30 PM
That probably wouldn't sound too great, I imagine. What are you wanting to do with the signal?
Time is a train
#7 radatats
radatats
    Power User
  • PipPipPipPip
  • 1035 posts
Posted 29 January 2014 - 02:33 PM
same as everyone else, run it to the PA... it is such a weak signal though and I can't understand why...
#8 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 5548 posts
Posted 29 January 2014 - 04:07 PM
Well the XLR out is mic level, not line level. So you have to take into a preamp and treat it like you'd treat a dynamic mic, more or less.
  • 1
Time is a train
#9 Brazzy
Brazzy
    Gear Head
  • PipPipPip
  • 717 posts
Posted 29 January 2014 - 05:32 PM
From what I'm gathering you can run the XLR out of the DT into the mic of the HD500 thru a clean channel and out the XLR's to PA.
I mostly play at home  and am always having fun learning how to play guitar so when I post a reply to try and help give ideas you know where I'm coming from. Rock-On!! Oh, and if I don't respond promptly I'm probably playing guitar or my computer locked up from multitasking 'cause I'm using Gear Box, HD500 Edit, Audacity and tab filled browsers all at the same time, Hahahaaaa. Surprisingly enough my 'puter handles the load more times than not. Lastly I'm not a salesman, I'm not trying to sell anyone anything here. "Riffcasts Riffworld" "RiffRumble Entry" "Shifftie" "M.O.S.U.A Two" "Bass Catszz" "Blasted Runtime Error I" "Match 30" "SoundCloud Playlist" "And Ya Know It"
#10 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 5548 posts
Posted 29 January 2014 - 06:35 PM
You shouldn't need to resort to that. Just take the XLR out into a channel strip on the mixer. As long as you're going into a strip with a mic pre, it should be fine.
Time is a train
#11 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 236 posts
Posted 30 January 2014 - 02:22 AM
This is NOT what Line6 support says. Below is a conversation I had with Line6Hugo (hmerida) about cab modelling, and LVM. Hope it provides some information on Line6's stance. Bear in mind that I asked basically these questions in a different support ticket, and some of the answers I got there do NOT agree with this info. So I think Line6 themselves have different answers depending on who you ask... Professional, eh?
Anyway:
Line6Hugo: When connected via L6 LINK, the cab model in the DT25 is simply being controlled by the HD500 User Interface. Using the default cab models (the ones which automatically pair with the preamp) should provide the same results when using the same preamp and default cab model in the DT25 stand alone.
Me: "In your explanation, the cab modeling is placed before the power amp, not after. Is this really the case, and if so, why is that? It makes much more sense to have it afterwards. Also, why is there cab modeling active in the dt25 standalone when it has a cab and speaker anyway?"
Line6Hugo: - Cab modeling exists in the DT25 to create a complete amp tone. If you prefer to turn it off you may do just that with a connected HD500 or in standalone mode when connected to a MIDI controller accessing the DT25 2.0 firmware features. Having the cab modeling before the power amp in the DT amps ensures a consistent experience when using with or without a POD HD device.
Me: "How does the use of LVM mode and the direct out affect the placement and operation of cab modeling?"
Line6Hugo: - LVM has no impact on the cab modeling. Direct out uses the same cabinet model through a model of the mic’ed DT25 cabinet. This provides a tone which matches the cab model that comes through the DT25 speaker through a mic, as you would here in a recording or through the PA… essentially the same experience you would get with a microphone but direct via XLR.
Me: "Finally, I notice a large difference on the B channel when I activate LVM. My test case is as follows: dt25 a and b channels set with all knobs to 12oclock, topology 2, P-75 Pre (no cab) I have a footswitch set to toggle the amp block on and off and they sound similar (but far from identical). However, if I engage LVM and toggle the amp block on and off, the B channel now sounds very different (much more distorted). Why is this, nothing in your explanation suggests why the power amp/LVM would behave differently."
Line6Hugo: - More information is required to properly answer this question – normally toggling an amp model bypass (on a connected HD500) also toggles the amp between channels A and B. If channel B is not set identically to the amp model when active, the sounds will be different. Also, each channel (if switching) must have its topology settings set identically. Engaging LVM does two things: uses HD Technology to deliver the preamp and power amp modeling (whereas non-LVM provides just the preamp model) as well as scales the level of the Master Volume knob on the DT25.
Some more conversations with support. might be of interest:
From 'afisher'
Hello,
With the DT in LVM and using the direct out, disabling the cab modeling on the HD500 will remove the cab modeling from the output of the DT.
Removing the cab modeling causes the mic modeling to be removed as well.
We tested this scenario here and our ears told us there was no perceived change in tone when changing mic models while the cab modeling is disabled. Thus, the mic modeling does nothing when no cab is being modeled.
#12 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 236 posts
Posted 30 January 2014 - 02:24 AM
As far as I understand it (not far!), there is no audio going back to the pod. The cab modelling is applied at/after the PREAMP stage only.
#13 radatats
radatats
    Power User
  • PipPipPipPip
  • 1035 posts
Posted 30 January 2014 - 04:19 AM
thanks for all that!  as usual, they really don't know what the hell is going on because they will not release a simple block diagram of the actual signal path.  It is impossible for the cab modeling to be applied before the power section because it is already being applied there!  They are most certainly applying it a second time to the transformer tapped signal or there would be absolutely no need to mention it at all.  The only way that can happen is for that signal to be routed back in to the DT to have the cab modeling applied prior to hitting the XLR out.  From what I gather from all this discussion is the L6 signal tells the DT which cab is being used in the POD and the DT applies that cab model to the signal.
Line6Hugo: - LVM has no impact on the cab modeling. Direct out uses the same cabinet model through a model of the mic’ed DT25 cabinet. This provides a tone which matches the cab model that comes through the DT25 speaker through a mic, as you would hear in a recording or through the PA… essentially the same experience you would get with a microphone but direct via XLR.
So this kind of makes sense.  I have to picture this XLR out as representing a mic placed in front of my cab/speaker so even though the tone coming from my cab/speaker is being created with a modeled amp and cab sim, the mic would capture a second physical cab effect and that is what they are trying to recreate.
#14 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 5548 posts
Posted 30 January 2014 - 04:45 AM
I don't believe I said anything that contradicted what Hugo said there. You asked specifically about LVM. I was answering as if the DT was in regular power mode.
Time is a train
#15 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 236 posts
Posted 30 January 2014 - 05:31 AM
I meant that some other line 6 supporter gave contradictory info. Unfortunatel' they seem to have deleted that ticket, I can't find the conversation. My point is that the line 6 support guys give hazy, ill-defined answers because they don't actually know any better imho. I pressed them really hard for a signal chain block diagram, but 'the display on the pod shows the signal' was the best I got from them. Gah!
#16 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 236 posts
Posted 30 January 2014 - 05:35 AM
Radatats: line6 were adamant that no audio goes from the dt to the pod. The dt can do the cab modelling. It makes sense to me to do it while the signal is still digital, and not after the power amp, even if thats where it should be done for most realistic effect. Why don't you think its done earlier in the chain?
#17 radatats
radatats
    Power User
  • PipPipPipPip
  • 1035 posts
Posted 30 January 2014 - 06:07 AM
I am not saying anything goes back to the POD from the DT.  But you are missing the point here.  The signal is created in the POD with modeled amp and cab/mic sim applied.  This is then sent to the DT power section.  At the output transformer the main signal is sent to the speaker and another signal is tapped off for the direct out.  That tapped signal is what is routed back in to the DT to have the cab sim applied based on what model is selected in the POD and then sent to the XLR.  It never goes back to the POD.  This signal now imitates the signal that a mic placed in front of your cab would pick up and is available to send to the mixer for your PA.
If it was done earlier in the chain it would not be able to capture the tube power section flavoring.  I guess my biggest gripe was the weak signal but it is what it is...  I can deal with it now I really understand it.
#18 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 236 posts
Posted 30 January 2014 - 06:14 AM
What suggusts that cab/mic modelling is applied again? I'm not saying its not, but what makes you think it is?
#19 radatats
radatats
    Power User
  • PipPipPipPip
  • 1035 posts
Posted 30 January 2014 - 06:26 AM
They state that it is! Its a CAB SIMULATED DIRECT OUT!  the cab sim imitates the physical speaker.  two paths out of the transformer, one to a real speaker, the other to a cab sim (speaker replacement)...
#20 MartinDorr
MartinDorr
    Iknowathingortwo
  • PipPip
  • 236 posts
Posted 30 January 2014 - 06:41 AM
I am in innovine's camp. Nowhere does it say the Cab sim is applied to the transformer tapped signal directed to the XLR out. It is much more likely (less DA/AD converters are needed) that the Cab sim is happening in the tail end of the preamp model, i.e., in the HD when an Amp is selected and L6 Link is used, or in the DT if you come in with a guitar or via Channel B when no Amp is selected in the HD.
Another indicator why this is likely is that both Master Volume and Reverb are applied BEFORE the DT effects loop, i.e., the analog signal coming back from the effects loop is probably not converted back to the digital domain to do an extra Cab and Mic modeling step. If the extra AD/DAs would exist, it would make a lot more sense that reverb and master volume would also be done after the effects loop.
Obviously we're all just guessing with spotty and conflicting feedback from several sources and probably no real measurement data we acquired ourselves.
Martin
#21 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 5548 posts
Posted 30 January 2014 - 09:09 AM
Yeah, I think you're right. I think perhaps we need to step back and kind of look at the bigger picture again. Remember that the DT amp itself contain all the amp and cab modeling that the POD HD does, for starters. When you use L6 Link with the DT in full volume mode, no modeling is being done in the DT itself, except for what happens to the XLR out. You have the preamp signal coming through L6 Link, it hit the power section of the amp in whatever way it configured, goes to the output transformer and out the speaker. The signal going to the XLR out would have cab and mic modeling applied in the DT amp itself before it leaves the amp. This is essentially having two layers of cab modeling if you have the Cab on in the preset in the POD, but, really, you have that with the real cab, too. In the combo or stack power amp modes, the cab modeling from the POD is more re-voiced, anyway. It's really more like an EQ applied to the signal to give the flavor of the amp being modeled.
In LVM, nothing changes on the POD side. The DT, however, bypasses all the topology, class, and other settings associated with the real power amp. Those settings still affect the sound, but the power amp is now being modeled. So you have the POD providing the pre side of the modeling and the DT providing the power amp modeling. Hugo said the cab model doesn't change on the XLR out, and that makes sense. That doesn't mean the output would sound the same, though. It might be very close, but it should be a little different because in full power mode, the signal going to it is going through the real power amp, and in LVM it's going through the modeled power amp. In either case, there's another lay of cab modeling applied to it. The signal is still tapped off the output transformer whether the amp is full or LVM.
This is at least how I understand it to work. I'm, of course, open to correction.
Time is a train
#22 ColonelForbin
ColonelForbin
    Iknowathingortwo
  • PipPip
  • 473 posts
  • LocationChicago, Illinois
Posted 30 January 2014 - 10:56 AM
Has anyone tested the difference in the DI out from the DT while changing cab choices in the HD? Or turning the cab selection to "none" in the HD? I would guess, that if what L6Hugo said, unless it defaults to some other cab sim, that if you choose none in the HD for the cab choice that the XLR out from the DT should sound horrible, as it does when you take the XLR off the HD while in combo/stack modes.
"Searching for a distant star, Heading off to Iscandar
Leaving all we love behind, Who knows what dangers we'll find?"
#23 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 236 posts
Posted 30 January 2014 - 02:05 PM
, but the power amp is now being modeled. So you have the POD providing the pre side of the modeling and the DT providing the power amp modeling...because in full power mode, the signal going to it is going through the real power amp, and in LVM it's going through the modeled power amp.
Well, the signal is always going through the power amp, since its loud and coming out the speaker. My asumption for how lvm works is that a dist is applied digitally, after the preamp (possibly after the loop) to fake a driven power amp, and then it's reduced in volume to give lvm mode, and then goes into the power section which runs pretty clean. The tap on the transformer goes to the xlr out and the full windings power the speaker.
#24 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 5548 posts
Posted 30 January 2014 - 03:13 PM
Yeah, agreed. The tube power section is still doing something. It just seems that in LVM, the distortion and topology characteristics are bypassed somehow, and the modeled version takes over.
Time is a train
#25 radatats
radatats
    Power User
  • PipPipPipPip
  • 1035 posts
Posted 30 January 2014 - 03:57 PM
From the L6 LINK™ Connectivity Guide:
Low Volume Mode Switch
Pull the Master Volume knob on DT50, or use the switch on the back of DT25 to toggle the Low Volume Mode “On.” Low Volume Mode functions independently of POD HD and significantly lowers the overall DT amplifier’s volume level. Way beyond a traditional master volume, Low Volume Mode lets you take your DT amp down to whisper-quiet levels for recording or late-night jamming. Since tubes distort less at low volumes, Low Volume Mode utilizes HD technology to pick up the slack and fill out the tone with rich power amp modeling so it still feels and sounds like it’s cranked up even at low levels (Also see the Direct Out functionality on page 4•6.)
So LVM configures the DT power section to either be all tube (off) or adds power amp modeling (on) to the L6 signal prior to hitting the tubes.  Either way, it does not affect or change anything in the POD, just how it acts upon the signal it gets from the POD.
Here it gets confusing again...
D Direct Out
The DT amplifier’s DIRECT OUT continues to function as an analog output with L6 LINK in use. Use of this XLR output is recommended to feed your “fully baked” POD HD + DT amp tone to an external recorder, mixing console, etc. Since the audio signal fed to the DT amp via L6 LINK is a mono signal, this Direct Out is a mono signal as well. Note that the Direct Out functionality differs based on the DT amp’s LOW VOLUME MODE (see page 4•3) and STANDBY switch settings:
• Low Volume Mode Off, Amp in Standby = The DT amp’s Direct Out is disabled.
• Low Volume Mode On, Amp in Standby = Direct Out signal consists of the “Full” (preamp + power amp) Amp Model with no analog amp. This is a handy option for “silent recording” while still providing the tone of a cranked amp.
• Low Volume Mode Off, Amp On (not in Standby) = Direct Out signal consists of the “Preamp” Amp Model with the analog amp.
• Low Volume Mode On, Amp On (not in Standby) = Direct Out signal consists of the “Full” Amp Model and the analog amp.
This description makes sense if you consider the DT as standalone but not if you are using L6 link.  LVM does not change what is coming from the POD so your pre or full amp is dependent on your patch, not the LVM switch.  They also fail to address the cab sim part for the direct out again...
#26 MartinDorr
MartinDorr
    Iknowathingortwo
  • PipPip
  • 236 posts
Posted 30 January 2014 - 04:14 PM
Where does it actually say that Cab modelling is done in the DT when L6 Link is used. I though having read it, but I can't find it anymore.
I have no dout that Cab modelling is an option when the DT preamp models are used because at least the MIDI guide says so (and there may be other statements in the user doc).
Maybe we're chasing a ghost (Cab modeling) and the DT's really only factor a real power amp signal distortion into the XLR out signal when the DT preamp models are not used?
#27 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 5548 posts
Well, the cab sim remains the same whether you're in LVM or full power mode. The cab and mic applied to the output will just be the same as whatever you have selected in the preset on the POD.
Time is a train
#28 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 5548 posts
Posted 30 January 2014 - 04:21 PM
That could be a possibility as well, I suppose. Although, I think I was just assuming that since the DT is capable of applying cab and mic modeling on the output on its own, it should be fully capable of doing it with the POD attached, too.
I guess my question is why does all this matter? Is there something you're trying to do that's not working the way you want? Or is it just curiosity about how everything works? Frankly, Line 6 has never been all that great about giving answers to these sort of "sausage-making" questions. I think they just assume most people don't want or need to know. I understand how it's frustrating to some people.
Time is a train
#29 radatats
radatats
    Power User
  • PipPipPipPip
  • 1035 posts
Posted 30 January 2014 - 04:31 PM
you nailed it!   :angry:  :wacko:  :blink:  :huh:  :)  :lol:  :D
#30 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 236 posts
Posted 30 January 2014 - 10:22 PM
"if it sounds good it is good" seems to be their philosophy, but i wonder if the signal chain is such a mess that they can't reveal it cos it would damage their product credibility. When you start to read threads like this you start to wonder how its possible to create such confusion about something which should be pretty straigtforward. something smells with the whole thing. And besides, "if it sounds good it is good" doesnt help when things dont sound good.
#31 MartinDorr
MartinDorr
    Iknowathingortwo
  • PipPip
  • 236 posts
Posted 31 January 2014 - 08:29 AM
That pretty much sums it up nicely ...
#32 Brazzy
Brazzy
    Gear Head
  • PipPipPip
  • 717 posts
Posted 31 January 2014 - 10:12 PM
Just for the heck of it I ran that XLR Direct Out from my DT50 Head (using LVM) into the Mic input of my HD500 turned the mic pot all the way up and then proceeded to make a few stereo patches using Amp Models and effects and recorded some tracks with Audacity to my hard drive, (I know there are better programs out there). With very minimal tweaking I had some very good quality sound tracks. It surprised me as I'm really always learning with this stuff. I was just amazed at how full the tracks sounded. I recorded silently monitoring from the pod with Beyerdynamic DT990 (600 Ohm) headphones and the monitored sound was identical to the recorded sound, IMO.
Also tagged with one or more of these keywords: dt, xlr, recording, direct out, cab sim, pod, hd, pa
