Hd500x And Variax Problem
variax hd500x volume
Best Answer WardMan , 30 January 2014 - 03:35 AM
Please clarify exactly how you have things hooked up when you get the problem.
Is it Variax 600 -> VDI -> HD500X -> L6 Link -> DT25   and all sound cuts in and out on your DT25 ?
If you replace the Variax 600  -> VDI  with Strat -> 1/4 inch cable  then everything is fine?
If you use the Variax 600 with VDI with X3L is everything OK?
If that is correct then you have narrowed the problem down to the VDI socket on the HD500X.   It could be that there is a bent pin in the socket or maybe some dirt - so it is worth giving it a quick clean with some switch cleaner.  It is also worth trying to use the short ethercon cable that came with the Variax for use with the USB dongle - the one that only has the lockable shielding at one end) - and see if that works.   It is also worth trying just a standard Ethernet cable just to see if that works.  If the problem continues after trying cleaning and different cables, then I suggest you send the unit back and ask for a new replacement.
Thanks. It's routed exactly as you've outlined. When it does cut out, I try the tuner on the HD500X and there's no signal so it does look like it's the VDI socket. I'll have a good look at it tomorrow and see if it's dirty.
I didn't get the USB dongle with the Variax, but I have a spare network cable I'll try out just to eliminate the possibility of it being the VDI cable.
Thanks for your suggestion.
Go to the full post
7 replies to this topic
#1 WardMan
WardMan
  • 17 posts
  • Registered Products:3
Posted 29 January 2014 - 08:31 PM
So, my brand new HD500X came yesterday. I've already got a DT25 and a Variax 600. Hooked it up using the L6 Link and the Variax VDI Cable.
Problem - the sounds cuts in and out.
Tried it with a 'normal' guitar plugged in - no problems. Tried it with Variax plugged in - problem returns.
Plugged Variax into my old X3L - no problems. Signal gets through ok and no problems with tone.
So at this stage I'm thinking the problem is inside the HD500X. The VDI cable is ok because it works in the X3L, the L6 Link is ok, the rest of the HD500X is ok because the strat worked through it.
Am I missing something here, or have I got a dodgy POD?
Variax 600 > HD500X > DT25  | Pro Tools  | Amplitube
By day I'm a financial planner - at night I play guitar and blog about guitar stuff over at Strictly Guitar
#2 cruisinon2
cruisinon2
    Uber Guru
  • 5423 posts
  • Registered Products:5
Posted 29 January 2014 - 08:45 PM
You seem to have ruled out all the other components...maybe try updating/reflashing the latest firmware on the HD. Other than that I'm out of ideas.
#3 WardMan
WardMan
  • 17 posts
Posted 30 January 2014 - 01:04 AM
Forgot to mention I've already done that. Thanks for the idea though.
Anyone else?
#4 edstar1960
edstar1960
    Power User
  • PipPipPipPip
  • 1664 posts
  • LocationUK
  • Registered Products:7
Posted 30 January 2014 - 02:56 AM
#5 WardMan
WardMan
  • 17 posts
Posted 30 January 2014 - 03:35 AM   Best Answer
#6 WardMan
WardMan
  • 17 posts
Posted 30 January 2014 - 08:01 PM
Sorted (I think). Had the wrong power lead plugged in - I only had a choice of 3 on my powerboard. Obviously need to get my eyes checked!
Plugged in the correct Line 6 lead and it works fine. Also nice to see they've gone to a DC adapter now rather than the AC adapters they used to use which were so hard to get replacements for here in Australia.
Just played for a while with the correct power lead plugged in and the problem didn't occur so hopefully it is fixed.
#7 edstar1960
edstar1960
    Power User
  • PipPipPipPip
  • 1664 posts
  • LocationUK
Posted 31 January 2014 - 02:47 AM
Great news.  Glad its sorted.
#8 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 31 January 2014 - 06:27 AM
I think Line6 should have changed the power plug when they changed their power supplies from AC to DC.  Most of us have the old ones laying around and it's easy to plug in the wrong one.  Even if you are aware of the difference it's easy to make a mistake if you are moving your stuff around often.
Also tagged with one or more of these keywords: variax, hd500x, volume
