Suggestion For Pod Farm
2 replies to this topic
#1 auto-da-fe
auto-da-fe
  • 9 posts
  • Registered Products:2
Posted 30 January 2014 - 02:02 PM
This may have been mentioned before if so, apologies.....(And before you mention iLok, nothing I have uses iLok, and I won't go there)
I recently moved my DAW (Sonar X3d) to Laptop. I am pretty portable now, but I do not drag my Pod XT around with me so when I am in another part of the house or out of the house my Podfarm FX stop working.  As result,  more and I more do not use Pod Farm.
Is there a way you could put a timer on Pod Farm such that if is has not connected to the Dongle in 12 or 24 hours it stops working ?
Therefore I could keep using it and once it is back in the studio I can tag up.
JR
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 30 January 2014 - 03:21 PM
No, but if you buy a pod farm 2 license it will work hardware independent.
I think you would also need to buy the power pack to have the standard XT models.
  • 1
#3 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7362 posts
  • Registered Products:6
Posted 30 January 2014 - 04:56 PM
+1 to Zap.
Also, if per chance it is a PODxt Live, you also may need the FX Junkie add-on.
Typically a PF license plug-in license gives you all the standard models plus the add-on you purchased, not hardware enabled ones, which the Power Pack technically is for the xt series (as is FX Junkie for xt Live).
FWIW, way back when,  I purchased all the add-ons except the Power Pack (because it came with a firmware update for the xt.
Then when I purchased the Gearbox plug-in (now POD Farm), I had access to the Power Pack without the xt connect, not sure how that all pans out now.
