Amplifi 75 - Crackling?
3 replies to this topic
#1 krisvibe
krisvibe
  • 7 posts
  • Registered Products:8
Posted 30 January 2014 - 05:45 PM
Hello there -
Just received my Amplifi 75, plugged it in and played for a bit, then out of nowhere a faint (but audible) crackling sound started to come through the amp. Unplugged the guitar, cable and Bluetooth - still there.
I'm not sure if the amp needs to "burn in" for a bit, or should I just go ahead and return it?
Any thoughts would be appreciated - thanks!
#2 Tones2
Tones2
    Iknowathingortwo
  • PipPip
  • 210 posts
  • Registered Products:5
Posted 30 January 2014 - 06:45 PM
This is probably not it but just to be sure. A lot of times when I get amp crackling it's because of static, especially with the dry heat in the winter. If you amp is on carpet, try it somewhere on a hardwood floor or tile and will no shoes or socks on.
#3 Rowbi
Rowbi
    Uber Guru
  • Line 6 Expert
  • 8252 posts
  • LocationCambridgeshire, UK
  • Registered Products:20
Posted 04 February 2014 - 12:59 PM
Hello there -
Did you figure this out or is it still happening?
Have you tried it in another wall
Socket in another room if it's still happening?
Regards
Rowbi
www.rowbinet.co.uk
#4 krisvibe
krisvibe
  • 7 posts
Posted 04 February 2014 - 01:18 PM
Thanks Tones - this is probably what it is.  It has been sporadic and I don't have a good way to test it off of a carpet just yet.  I'll be sure to mark this as the solution if I can get a solid answer.
