Why No Replacement Piezo Elements For Jtv69?
155 replies to this topic
#121 paulm_80526
paulm_80526
  • 33 posts
  • LocationFort Collins, Colorado
  • Registered Products:9
Posted 08 March 2014 - 06:06 AM
In the case of my JTV with the Graph Techs, the entire saddle body is "ringy", not so much the string behind the saddle. I posted a video on YouTube.
In the case of the Parker Nite Fly, it's definitely the string, though. Common problem. I have a friend with a Nite Fly that has the same issue.
40 Years of Guitar Fun.
Lotsa Line6 stuff including multiple Variaxes and now...
an Amplifi 150.
#122 paulm_80526
paulm_80526
  • 33 posts
Posted 08 March 2014 - 09:06 AM
Take it to a Line 6 authorized service center that knows the JTV's.
Piezos can be a touchy thing.
 Not sure a Line6 Service person would mess with my JTV now that I've swapped out the piezos. Plus I'm having fun experimenting at this point :-)  I'm happy enough with the sound now, but will continue tweaking.
On the piezo thing, there's some interesting stuff on the web. E.g.,
http://www.acs.psu.e...rs/pickups.html
http://en.wikipedia....iezoelectricity
an Amplifi 150.
#123 psarkissian
psarkissian
    Line 6 Staff
  • Service Engineer Moderator
  • 1398 posts
Posted 10 March 2014 - 07:20 AM
"Not sure a Line6 Service person would mess with my JTV now that I've swapped out the piezos"---
Being the JTV service guy at Line 6, yes,... I would,... but I don't know if it would be warrantied at this point.
But I'd service it anyway. I'm here for when a teak goes wrong as well as the usual JTV servicing,...
and unfortunately, I see plenty of those tweaks go wrong.
Please tread with care, it's not our father's old hollow body archtop. A JTV is a whole other kind of beast,
stroke and cuddle under the chin with care.
  • 2
#124 cruisinon2
cruisinon2
    Guru
  • PipPipPipPipPip
  • 4299 posts
  • Registered Products:4
Posted 10 March 2014 - 11:04 AM
Please tell me you're not the only one.... ;)
And since you've unveiled yourself...any thoughts on the crosstalk thread? I saw you posted in that one too. I'd love to figure out if my drop D issues are curable, or if it's peculiar to the way I play and would plague any JTV I tried...
#125 paulm_80526
paulm_80526
  • 33 posts
Posted 10 March 2014 - 07:33 PM
Not looking for and tweak rectification at this point, but I appreciate the offer!
What would be interesting to me would be some practical information about the JTV-69 piezo bridge. E.g., What changed between the original version of the JTV-69 Bridge (the one I have) and the current version (which I'll have soon, hopefully)? I know the PCB was moved to the backside of the block, but anything else? Do the saddles still have pointed adjustment screws and etched tracks? Also, I was wondering about your thoughts on "chassis ground" vs wired ground. Have you seen many instances where the LR Baggs "chassis" ground have become more-than-low-Z? What would one do to fix that? Also, what steps would you take to dial in a piezo saddle (either LR Baggs or Graph Tech Ghost) to get the best tone with minimal ringing?
Just FYI, I have 4 Variaxes. (2) 700s, (1) JTV-69 and (1) JTV-59. Love 'em all! Also have a DT-50, Amplifi, POD XT, POD X3 Live, and multiple DL3s.. Built my first guitar amp at 15 using SWTPC preamp/amp and some custom circuitry (sadly... 40 years ago), and love experimenting. I appreciate robust design and information; less interested in cuddling :-)
an Amplifi 150.
#126 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
  • LocationBurlington, VT USA
  • Registered Products:2
Posted 11 March 2014 - 03:27 AM
I'm a bit puzzled by the lengthwise position of those bridge pieces.  Is that really where they ended up when you adjusted the intonation?  Modern string sets with solid 3rd strings almost always require a distinctive 3-slanted + 3-slanted pattern where 6th and 3rd string are furthest from the nut, then 5th and 2nd, etc.
Also, the "clacking" you demonstrate in the video suggests that the bridge pieces are too tight against each other laterally - so when you loosen one screw it cannot twist enough to settle tight against the plate.  Is there any daylight at all between the pieces?  The original Variax pieces have about 1/64" of daylight between them.  I'm not sure what material the GraphTechs are made of, but you may want to consider grinding a bit off the sides to open some clearance.  They do say not to file the actual saddle area, but I doubt the pizeo element extends to the sides.
40 years of Rock-n-Roll and proud of it!
PRS Custom 24 (1990)
James Tyler Variax JTV-69(k) w/ Strat Neck
Fender / Roland GC-1 Guitar
Boss GP-10 13-pin Processor
Antares ATG-1 Autotune Pedal
Fender Mustang III.v2 Modeling Amp
#127 cruisinon2
cruisinon2
    Guru
  • PipPipPipPipPip
  • 4299 posts
Posted 11 March 2014 - 03:52 AM
Unless one really knows what they're doing, jury-rigging stuff that wasn't designed to work together is at the very least a pain in the arse, often more trouble than it's worth, and sometimes worse than having done nothing at all. Hats off to anyone for whom this kind of surgery is a walk in the park, but for me it's starting to seems like the JTV/Graphtec combo won't be an option. I can strip wires and solder, but I draw the line at grinding metal. I think I'll stick with what I got...limitations and all...Just don't see it ending well.
Or I'll buy an 89 and put the wrap-around Graphtec bridge on it...that shouldn't require a welding torch or anything, right? ;)
#128 paulm_80526
paulm_80526
  • 33 posts
Posted 11 March 2014 - 04:50 AM
Hadn't adjusted the bridge for intonation when I made the video. Was mostly interested in demonstrating the clacking or ringing. Have done that since, though, so now a D chord is tolerable 12 frets up :-)  The intonation adjustment had no effect on the clacking.
Very good theory on the cause of clacking. Turns out, though, that there is a gap laterally between the GT saddles, Definite daylight. So I don't think it was a "floating screw" due to the saddles not being able to rotate due to lateral contact when the set screws weren't even. What I'm thinking is that the long tails of the GT saddles may be riding unevenly on the bridge plate, with one side being forced down by the screw. It's hard to see if this is what's going on as the ridge at the back of the bridge obscures the tails. The original saddles keep the screw pretty much parallel to the bridge plate.
Anyway, as I said in the post above, the sounds is actually pretty good now that I've adjusted everything. I definitely happier than with my failing original bridge, and will play out with my JTV-69 again. There is still a tiny amount of piezo ring in some of the sounds, but certainly tolerable. I will do an A/B comparison for sure when I get the new LR Baggs bridge from Full Compass, and post the comparison.
an Amplifi 150.
#129 paulm_80526
paulm_80526
  • 33 posts
Posted 11 March 2014 - 05:02 AM
:-)   Probably no welding required, and I don't think any grinding either! There is lateral separation between the GT saddles.
I understand and respect your position on getting something known to work. Depends on your end game, of course. For me it's really fun to try new things and learn along the way. No one "really knows" what they're doing until they've done it, and usually more than once. E.g., Line6 seems to be continually updating released designs to make them better, as they seem to have done with JTV-69 bridge.
The sound is actually pretty good now that I've adjusted a few things, BTW.  As I mentioned in another reply, I'll post a comparison when I get the replacement bridge from Full Compass.
an Amplifi 150.
#130 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
Posted 11 March 2014 - 05:03 AM
Are you saying that the trailing edge of the new pieces might be in contact with the plate?
#131 paulm_80526
paulm_80526
  • 33 posts
Posted 11 March 2014 - 05:58 AM
I think that might be the case for some of the middle saddles, but hard to see. I've adjusted the overall bridge height to keep the outside saddles as low to the bridge as possible to minimize the intonation screw angle. On the Low-E there is a measurable gap between the bridge and the exposed tail.  But, the middle saddles have to be adjusted higher due to the curve of the fretboard, of course, and they could be touching.
Now that I'm back at my guitar, though, I'm not sure I'm seeing a strong correlation of the ringiness to saddle height above the bridge. So that may not be it...
an Amplifi 150.
#132 Charlie_Watt
Charlie_Watt
    Power User
  • PipPipPipPip
  • 2498 posts
  • Registered Products:6
Posted 11 March 2014 - 06:15 AM
How much did you have to adjust the string volumes to get them at the same levels of the old piezos?  When I did my 500 I had to go down to about 50%.   Full volume sounded terrible.
#133 paulm_80526
paulm_80526
  • 33 posts
Posted 11 March 2014 - 06:24 AM
About the same for the JTV-69, although I'm at Work, not Workbench right now :-)
I'll check and respond with numbers tonight.
an Amplifi 150.
#134 psarkissian
psarkissian
    Line 6 Staff
  • 1398 posts
Posted 11 March 2014 - 07:51 AM
Yes crusinon2,... I'm it. Would've thought the "US Service Technician & Moderator" was the dead giveaway.
The crosstalk issue,... a combination of playing technique and/or set-up.
It's usually good to have the set-up checked by a local guitar tech in your area,
who is authorized Line 6, and knows JTV's. Local, because climate will affect
the set-up.
"I know the PCB was moved to the backside of the block, but anything else?"--- No. If there was anything else, they haven't told me yet.
"Unless one really knows what they're doing, jury-rigging stuff that wasn't
designed to work together is at the very least a pain in the arse"--- Right you are. Seen my share of Frankenstein'ed JTV's. Not always pretty, which is why they come across my bench in the first place.
#135 paulm_80526
paulm_80526
  • 33 posts
Posted 11 March 2014 - 09:44 AM
Wow - you're it for the US. Hats off to you - I'm sure you've seen some interesting... opportunities!
Quick question then, and not sure if you can answer this or not. Have you seen a Graph Tech retrofit for the JTV-69 that worked well, after you got things straightened out? I know you can't recommend that or suggest that anybody do it, but I'd be interested to know if there is an existence proof, in your opinion. I'm pretty happy with mine now, but interested in your opinion as well.
an Amplifi 150.
#136 cruisinon2
cruisinon2
    Guru
  • PipPipPipPipPip
  • 4299 posts
Posted 11 March 2014 - 09:56 AM
OK...really no need to get testy. I'm neither an imbecile, nor illiterate. I see your title now, and I saw it before. The title alone doesn't necessarily preclude there being more than one of you. And frankly, it surprises me a bit that they would dump the load of repairing every JTV in the country on one guy. That's all I meant. Would have thought the smiley face in my other post was a dead giveaway.
#137 psarkissian
psarkissian
    Line 6 Staff
  • 1398 posts
Posted 11 March 2014 - 11:49 AM
No worries, I'm not testy. I am sometimes in a hurry to get these responses out and though
I'm good with guitars, my typing skills can use some augmenting. "That's all I meant..."--- I figured
as much. Ah yes, the smiley face,... :)
They thrust this upon me because I asked for it. They know how much I like working on these.
There are also a number of Line 6 authorized service centers in America that are capable, so
I get some help. And there's my counterparts in the UK taking care of the Euro Zone. :)
I also own a 69 and two 59's. :) :)
  • 1
#138 cruisinon2
cruisinon2
    Guru
  • PipPipPipPipPip
  • 4299 posts
Posted 11 March 2014 - 12:12 PM
Fair enough...all good. :)
#139 Charlie_Watt
Charlie_Watt
    Power User
  • PipPipPipPip
  • 2498 posts
Posted 11 March 2014 - 12:34 PM
Glad to have you contributing here, psarkissian!!!
#140 psarkissian
psarkissian
    Line 6 Staff
  • 1398 posts
Posted 11 March 2014 - 12:54 PM
#141 paulm_80526
paulm_80526
  • 33 posts
Posted 11 March 2014 - 04:49 PM
Just checked my settings. I set them by comparing the magnetic pickup volume to the equivalent Spank models. From low to high: .49, .53, .54, .56, .59, .56. The piezo-based models are still a bit hot relative to the mags with these settings, but that's OK - helps drive the front end of my amp a bit more.
So... pretty close to where you ended up. Not distorting as far as I can tell, or if it is... it sounds good :-)
an Amplifi 150.
#142 arefadwani
arefadwani
  • 3 posts
Posted 14 January 2015 - 01:43 AM
I have a gold Variax 700. When a couple of my piezos went (I cant remember which strings), I replaced them with Graphtecs. I did the electronic part (fitting and soldering etc.. ) as I am an aviation electronics technician. Unfortunately, I could not get the intonation set. There just wasn't enough adjustment room on the bridge. I sent the guitar to a tech in London (Guitar Aid) and he had to reset the neck in order to bring the bridge adjustment into range. He did a beautfiul job and the guitar intonation and set up is now perfect. That was a few years ago and, after about 500 hrs of playing it, I have not had a problem since.
I dont know if the new JT Variaxs might have the same issue.
Oh, and the Graphtecs are much more powerful than the original piezos.
#143 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1953 posts
  • Registered Products:3
Posted 14 January 2015 - 04:02 AM
I've seen JTV piezos at fullcompass I think.
For a minute there, I lost myself.
#144 fr0sty
fr0sty
  • 80 posts
Posted 14 January 2015 - 12:50 PM
Is there an authorized repair center in MN that you would recommend? I would like to see if they can clear up the ghost notes/warble issue I have.
#145 psarkissian
psarkissian
    Line 6 Staff
  • 1398 posts
Posted 14 January 2015 - 01:21 PM
Ghost Notes (aka- hollowing or whistling) is typically a result of set-up,
either neck relief or intonation, or both. Most often it's intonation.
Warbling is typically a result of the set-up, usually relates to pick-up
height (most often, set too close to the strings). The magnet pulls on the
string causing a warbling effect.
http://line6.com/find/service_center/    for looking for a service center.
#146 fr0sty
fr0sty
  • 80 posts
Posted 14 January 2015 - 02:30 PM
Thanks, can you post setup specs for the jtv-69?
#147 stevekc
stevekc
    Gear Head
  • PipPipPip
  • 769 posts
  • LocationSan Luis Obispo, CA USA (central coast)
  • Registered Products:14
Posted 14 January 2015 - 04:02 PM
Yes Indeed! - Psarkissian is (what the kids like the say)  "You da'Man! for Tyler Variax repairs!"
Even my beloved JTV-59  (see my avatar on left) once developed an intermittent PU selector, and I got an RMA and my JTV-59 with Bigsby B7  spent quality time on Psarkissian's Line -6 Variax Repair bench!
Excellent Service and quick turn around too  !
#148 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1953 posts
Posted 14 January 2015 - 07:08 PM
What causes plunking noises?
#149 psarkissian
psarkissian
    Line 6 Staff
  • 1398 posts
Posted 15 January 2015 - 08:52 AM
Clay, et al- ... and remember, piezos are sensitive to impact shocks
that can damage them, so be careful when dealing with them.
Pluncking? Probably fret buzz or the nut slots need to be cleaned and de-burred.
fr0sty- set-up on a JTV can be tricky because of the Model processing.
this isn't your everyday kitty-cat, it's a tiger and has to be cuddled under
the chin a little differently. It's not our father's archtop hollow body with
passive electronics. The fact that pick-up height can affect Modeling
(ie- warbling) is a perfect example of that. I get a few back from those
who attempt and fail at an adequate set-up.
stevekc- thank you for the kind words. Quality time indeed, I didn't want
to part with it. Nice 59.
#150 Charlie_Watt
Charlie_Watt
    Power User
  • PipPipPipPip
  • 2498 posts
Posted 15 January 2015 - 11:29 AM
For those of us that do our own setups, it would be nice to have some specs or guidelines.  I am not convinced that they leave the factory set up perfectly and it does not make sense to send them off to a service center.  I am happy with my JTV69S setup but I have fooled with it a bit.  It has fret buzz on the LowE and A before I made some slight sting height adjustments at the bridge.
#151 cruisinon2
cruisinon2
    Guru
  • PipPipPipPipPip
  • 4299 posts
Posted 15 January 2015 - 12:27 PM
Don't hold your breath. Official edict will always be that no one but an "authorized tech" can do the work. If you don't happen to live in reasonable proximity to one, then you're SOL and your set-up now requires a cross-country trip with a turn around time that will take weeks?!?! That's nuts.
Personally I don't buy it. A guitar set-up should not require the services of UPS or FedEx. And it doesn't if you know what you are doing or have someone local who does, "authorized" or not. Variax guitars are unique, but not supernatural. I have had absolutely no issues doing routine seasonal tweaks that I've done to every guitar I have ever owned. I'm in the NE, so we get wide swings in temp and humidity around here, so all my axes need adjusting periodically. This one isn't any more complicated than any of the others. If it plays well and doesn't have any horrible noises emanating from it, then what use are the specs?
A major electronics failure would be a different matter of course, as neither I nor the guy who does my more complicated work would likely be able to fix it....but a routine set-up? Please...
#152 fr0sty
fr0sty
  • 80 posts
Posted 15 January 2015 - 01:32 PM
I agree.  fwiw, I just contacted an authorized l6 repair center "near" me about the possibility of the guitar's setup creating ghost notes and warble.  He never heard of it.
#153 psarkissian
psarkissian
    Line 6 Staff
  • 1398 posts
Posted 15 January 2015 - 01:35 PM
Have you checked the Line 6 Knowledge Base?
I gave a couple documents to be put up there last year,
regarding JTV's, forgot what it was.
The set-up isn't always as routine as you might think, given
the interactions in Model mode. The processor will try to deal
with fret buzz or warbling, as if it were part of the signal.
And there's probably something in our set-up doc that's
not meant for public consumption, that might factor into it.
Though I don't know what that would be off-hand.
#154 cruisinon2
cruisinon2
    Guru
  • PipPipPipPipPip
  • 4299 posts
Posted 15 January 2015 - 02:36 PM
Can't say I'm surprised. Over the years I have come to expect very little from "authorized service centers". This has nothing to do with L6 per se, the world of warranty repair is a universal disaster. I have experienced this numerous times with everything from guitars to motorcycles and everything in between. Makes one wonder what the process of becoming "authorized" actually entails, as it often seems to be a meaningless designation.
When I took my Stagesource L2T to the "authorized service center" just the other day and described the issue with the fan assembly and associated rattle at high volume, I was given the exact same response..."never heard of it". Common enough problem that required L6 to design a new part and do lots of warranty work, yet the "authorized service center" to which I was directed was mystified.
#155 Charlie_Watt
Charlie_Watt
    Power User
  • PipPipPipPip
  • 2498 posts
Posted 15 January 2015 - 03:31 PM
My point exactly.  I trust my own skills far more than most "authorized dealers".  Sure there are some good ones but how many have really been trained and have the skills that psarkissian has.  I do not doubt for a second that  he would do a great job diagnosing setup problems but I bet most shops don't really have those special "Variax" setup skills. That is a much different skill set than swapping out components until the problem is solved that you find at many repair shops.
#156 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1953 posts
Posted 16 January 2015 - 05:41 AM
The attack on my variax on the E string is very plunky  compared to the rest of the strings. This complaint has had multiple topics about it. A lot of them alluding about the mass of the big E string, but the fact is that this doesn't happen on all Variax guitars.
I put a few layers of tape between the piezo and string to try to dampen it but it's still there unless I turn down the treble on my POD. Wasn't there until I cleaned the piezo with contact cleaner and actually replaced the piezo (still there).
Just wondering if I could get info from you since you work on the guitars.
