bsheen Posted February 2, 2014 Share Posted February 2, 2014 Anyone else having issues with the dual amp not working? Amp A hard left works, but amp b hard right =nothing. Thought it was a glitch in a preset I built, but just tried building a brand new preset and it isn't working either. Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 2, 2014 Share Posted February 2, 2014 Could be an issue with signal flow and Inputs. If your preset has no FX before the path split, and if Input 2 is set to a physical input that has nothing connected, you will get what you describe. Quote Link to comment Share on other sites More sharing options...
bsheen Posted February 2, 2014 Author Share Posted February 2, 2014 Copy that Silverhead! Appears the culprit was the "input 2 source". I had seen on here before that changing the input 2 would help out with patches having more distortion than what was actually in the patch. I had changed it to AUX, but that was on a single amp patch. It seems to be okay now. Am wondering now what that whole idea was that I read about before was. Quote Link to comment Share on other sites More sharing options...
bsheen Posted February 2, 2014 Author Share Posted February 2, 2014 Well that is an issue. On single amp patches when you change the input 2 source to anything other than AUX there is alot more distortion being added. When its set to AUX the distortion is less and it sounds more natural like coming just from the amp. Otherwise it sounds like there is artificial distortion being added in. However on dual amp mode it doesn't seem to change the sound when choosing a different input. Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted February 2, 2014 Share Posted February 2, 2014 Well that is an issue. On single amp patches when you change the input 2 source to anything other than AUX there is alot more distortion being added. When its set to AUX the distortion is less and it sounds more natural like coming just from the amp. Otherwise it sounds like there is artificial distortion being added in. However on dual amp mode it doesn't seem to change the sound when choosing a different input. Read this thread for a full description of routing in HD500: http://line6.com/support/topic/2033-pod-hd-500-500x-new-routing-schematics/ There are other threads that discuss the input 1 and input 2 options and uses and end results depending on how patch set up. Quote Link to comment Share on other sites More sharing options...
