Floor Pod Plus Help
floor pod plus amp floor pod plus amp
1 reply to this topic
#1 kamijo
kamijo
  • 5 posts
  • Registered Products:1
Posted 04 February 2014 - 02:48 PM
I need help in knowing how to connect my guitar, Floor Por Plus pedal and my amp. My amp has the SEND/RECIEVE inputs and I want to use the amp presets inside the Flood Pod Plus as well as distortion and other effects. Thanks.
#2 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
  • Registered Products:8
Posted 18 March 2014 - 11:04 AM
The simplest way is to use the effects loop (line in -> effects receive) jack and use your amp as a power amp. With the amp off, turn the FPP on, turn the volume way down,  and have the volume pedal backed off then turn the amp on - then adjust your volume levels on the FPP. This will help save a mighty blast and pop through your amp.
There are other methods - like using your amps pre and looping the FPP. I use the above with a combo at practice as its quick and easy.
Smell the glove.
Also tagged with one or more of these keywords: floor pod plus amp, floor pod plus, amp
