Pod Hd500x Usb Connection Help!
6 replies to this topic
#1 linea06
linea06
  • 14 posts
  • Registered Products:2
Posted 09 February 2014 - 02:36 PM
Hi Guyz New to the Pod Hd 500x and just wondering if there is a setting that i need to make to get my pod to come thru my comp speakers.. I m under the impression that I'm so posed here my pod thru my comp speakers when i use the edit program.. i have downloaded all driver and latest firmware and flash memory!! if there is a post on this already please direct me to the right one thanks!!! :)
#2 pokasd1
pokasd1
  • 1 posts
Posted 12 February 2014 - 12:39 PM
i have the same problem, someone help please :unsure:
#3 NeedmoreCrunch
NeedmoreCrunch
  • 14 posts
Posted 13 February 2014 - 07:25 AM
Once your POD is plugged into the computer (USB) and is turned on you need to select the pod as a "playback" device in your sound properties.  You can do this in your control panel on your computer, or right click the speaker in the system tray and select "Playback devices", select the Line6 POD as the playback device and click the "set default" button then click "ok".
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16051 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 13 February 2014 - 07:43 AM
When the POD is connected to your computer it becomes your soundcard. You need to connect your speakers to the POD outputs to hear the sound.
.... John Lennon
#5 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 13 February 2014 - 08:41 AM
The POD's USB doesn't really carry an analog sound signal, even though it can be used for ASIO recording.  As silverhead said, you really need to attach active speakers directly to the POD.  Another solution, which I personally use, is to connect the POD's analog outs to the AUX Input of my PC's sound card.
There are some work arounds to use the USB ASIO audio, but there is quite a bit of latency, and most folks find the latency unworkable.
#6 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 13 February 2014 - 09:06 AM
Check also this:
Video Tutorial: How To Record on Your Computer Using POD HD
#7 linea06
linea06
  • 14 posts
Posted 13 February 2014 - 12:01 PM
Thank guyz.. I know i did something the other day and the sound came from the pod to my speakers... With all of this advice i should be able to do again...LOL..
