4 Cm Method Without '"send" Jack
hd 500 4cm
3 replies to this topic
#1 Lario1
Lario1
  • 1 posts
  • Registered Products:1
Posted 10 February 2014 - 06:31 AM
Hi I bought homemade tube amp. However it has main input jack and return jack (access to power amp) only. There is no "send" jack from preamp. Is there any possiblity to use fx loop of my POD HD500? I would like to use preamp of this head.
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8949 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 10 February 2014 - 07:05 AM
Not that I can think of. It's weird that whoever built the amp would go to the trouble of putting the power amp in jack and not put a preamp out. I would think it wouldn't have been much more work to add that. Probably you're best bet is taking it to a qualified tech and having him add that jack. Should be a relatively simply mod.
#3 aggravation
aggravation
  • 87 posts
Posted 10 February 2014 - 06:33 PM
Does it have a reverb unit in it?
You might be able to employ the reverb send.
Don't do it without someone smarter than me to tell you how though!
I think in most cases it requires a few additional components in the signal path before you could just plug it into something....
#4 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1198 posts
Posted 10 February 2014 - 08:17 PM
Most likely it is to save the pre being used without a load which will ruin it.
I don't know how it saves it when power amp in being used.
Usually you find only an ext speaker jack in all but the better units.
If it is homemade then there will be a place to tap into the pre as a send. You could get the maker to put this in.
You can still go in from the HD selecting "combo" in the menu and rolling off alot of top end and not selecting or turning off amp model in the HD..
Consider the HD a pedalboard into the amp and tweak till pleased.
If you get the send installed into the amp then you get the best of both worlds using the 4CM.
Also tagged with one or more of these keywords: hd 500, 4cm
