Pod 2.0 Comes On But No Output/input Signal. Tuner Doesn't Even Work.
4 replies to this topic
#1 ixagr8
ixagr8
  • 2 posts
Posted 10 February 2014 - 11:09 AM
I have an older 2.0 Pod that just stopped working. I have no output and the tuner doesn't even register.
Suggestions?
#2 cruisinon2
cruisinon2
    Uber Guru
  • 5162 posts
  • Registered Products:5
Posted 10 February 2014 - 11:20 AM
Suggestions?
If the tuner isn't registering, the unit may not be receiving any signal at all. Could be either dead cable or dead 1/4" jack on the guitar (usually just a loose solder connection). Try another cable first, if it still doesn't work, then try another guitar.  Sometimes it's the simple things...
#3 ixagr8
ixagr8
  • 2 posts
Posted 10 February 2014 - 11:28 PM
Cord=Good
Guitar=Good
I'm beyond the simple things.
There is no input or output signal. Channels function ok. Did a factory reset; pod boots up to "1 A" everytime.
Lights are on but nobody's home. No buzzes like cold solder joints or bad ground.
I'm thinking it's a factory RMA that's gonna get 'er working again.
I appreciate your comments and if you think of anything else, please holler!
Thanks!
#4 Mr_Arkadin
Mr_Arkadin
    Guru
  • PipPipPipPipPip
  • 2817 posts
  • Registered Products:6
Posted 11 February 2014 - 01:56 AM
Are you using the original PSU?
#5 jayofava
jayofava
  • 6 posts
Posted 09 March 2014 - 09:24 AM
I had the same problem. Make sure your using the correct power supply.
