How To Assign Delay To Expression Pedal?
ChaserHUN
Not near my unit, however...go to the Controllers tab in the Edit program...select the delay from the dropdown list and then in the list next to it, select what you want to control and then in yet another list, choose the expression pedal to assign it to.  Then save the patch.
Did that and nothing :S
Smrybacki's method should work for assigning delay feedback. However, if you were trying to assign delay time there is another setting that is relevant. You can assign the delay time using the Tap Tempo switch. For this to work you assign the tempo parameter as a note-based unit. If that is the way the delay FX in your preset is configured, then you control delay time using the tap tempo switch; you cannot further assign the delay time to the pedal. In order to assign the pedal to control the delay time you will have to set the tempo parameter to a number of milliseconds rather than a note. Then you assign the pedal min/max values in terms of ms.
