Pod Hd500x
pod hd500x
17 replies to this topic
#1 RyanOgle
RyanOgle
  • 1 posts
  • Registered Products:1
Posted 12 February 2014 - 05:28 PM
Hola,
I just got my POD HD500X from Musician's Friend today. Does anyone have any tips, advice or anything of that nature?
For a little insight -  At home, I'll be running it through 2x12 Spider combo amp or one of my PCs; musically, anything goes.
For practice/gigs, I use a Blackstar Stage 100 and Mesa 4x12. We're death metal with old-school & thrash influences.
Any feedback is appreciated.
Cheers.
Ryan
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15923 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 12 February 2014 - 05:34 PM
There are dozens (probably more) threads already in this forum that deal with exactly this. I think you'll learn a lot by doing a little searching and reading here. Reading the manual is a good start, too.
Then you will have some specific questions to help you further once you've got the basics.
.... John Lennon
#3 henrylita
henrylita
  • 2 posts
Posted 12 February 2014 - 10:10 PM
HI,
HOW CAN I HAVE THE PROGRAM EFFECTS FOR MY PEDAL, I HAVE POD HD500 PLEASE HELP ME WHIT INFORMATION ABOUT MY POD.
THANKS
ATTE
HENRY
#4 GrantRowlands
GrantRowlands
  • 6 posts
Posted 26 February 2014 - 11:28 PM
Hello from a newbie,
I'm thinking about getting a pod hd500x, to use with my two spider valve amps.
I like running two amps together, and having different amp tones on each amp.
What I would like to know is, if it is possible to use the hd500x so that i can run two different amp types out of the pod, using left and right outputs - going to the two spider amps.
I am aware that you can have a dual amp rig within the hd500x, but can that configuartion remain separate through the unit, and remain that way - out of the L & R outputs. I would like to be able to set up two different amp and effects chains in the pod, and send one amp sound L to one of my spider valve amps, and the other amp tone R to the other amp.
I do realise there are lots of different possibilities to achieve the same thing - just using the two spider valve amps, without anything else. However, Like the DT25 / 50 can do with a pod, I would like to have even more options available from the pod, and run into the power amp of each spider valve amp.
Does the hd500x work that way, or is it able to be set up using a combination of two amp and effect chains - which are then mixed together to get one unique amp sound - which then goes to the outputs ?
Have I explained what I would like to achieve with an hd500x ? As i said, I am a newbie, and thought this would be the best place to ask this question.
Thanks for any help. I didn't see this question asked or answered anywhere else . . . or have I missed something  ;-)
Cheers,
Grant.
#5 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 27 February 2014 - 02:07 AM
I beleive the spider valve amp does not match/integrate with the HD500 the way the  DT25/50 does.
However u could achieve what u described.
Consult the following:
http://foobazaar.com/podhd/toneGuide/
http://line6.com/sup...ing-schematics/
#6 WaubinHood
WaubinHood
  • 49 posts
  • LocationFinland
  • Registered Products:4
Posted 27 February 2014 - 04:15 AM
You can't control your Spiders via Line6 Link. Err.. If willing to tamper with MIDI - and them Spiders have it - at least one amp can be controlled with it, i believe. But. It is possible to make stereo setups for your 2 amps. After all, you do get stereo outputs when you get your HD.
Aaand it is possible toi make separate effect chains. Fine details can be found in manuals.
#7 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
  • LocationOrange County, NY
  • Registered Products:3
Posted 27 February 2014 - 04:20 AM
HI,
THANKS
ATTE
HENRY
Read pages 3-7 to 3-10 of the advanced guide, it tells you how to program the expression pedal.  Look in the Knowledge Base too and Google You Tube.
  • 1
#8 GrantRowlands
GrantRowlands
  • 6 posts
Posted 27 February 2014 - 08:31 AM
Thanks for the replies. I understand that the spider valve mk ii doesn't have the connectivity with a hd500x that at dt25/50 has. I was not hoping to achieve anything like that. I only want to use the L & R 1/4" outputs from the pod - sent to each spider valve amp return / power amp input. Basically utilzing the ability of the pod, to provide an alternative front end for the spider valve.
The question was basically  >  from one guitar input, can the signal be split to two separate chains - with whatever amp and effects are in each chain ( without having to combinie the dual chains at the mixer)  >  send the seperate chains to the L & R outputs > on to the spider valve amps ?
I only want to use the pod to provide 2 chains  >  one going R, the other going L.  I would have thought that it was 'do-able' with the power of the 500x, and with all the I/O available . . . ?
I don't want to get in pedantics, or all the technical stuff,  or the rights or wrongs of what I am wanting to achieve. I don't 'know' much at all about the possibilities or fine workings of the the beast. I can hopefully learn the marvels of the hd500x as I progress. However, if what I am wanting to do - can't be done - I won't buy the hd500x. There are other ways to achieve what I am wanting to do - i just wondered - for simplicity sake, and floor space - if i could achieve that aim with the hd500x.
Thanks for your input.
#9 GrantRowlands
GrantRowlands
  • 6 posts
Posted 27 February 2014 - 08:33 AM
well I stuffed that "reply to two people with quotes" up well and truly    :-))    just read the legible bit !!
#10 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 27 February 2014 - 08:34 AM
Yes you can do this.  The chains are stereo but you can set it up to one channel gets one path and the other gets the other path.
#11 GrantRowlands
GrantRowlands
  • 6 posts
. . .  and again . . .   I found the 'clear' button now. I will get it right. Sorry for the mess on the page.
#12 GrantRowlands
GrantRowlands
  • 6 posts
Posted 27 February 2014 - 08:35 AM
Thank you. That's all I wanted to know  :-)
#13 henrylita
henrylita
  • 2 posts
Posted 20 April 2014 - 07:44 AM
HOLA,
Ihave a question about my pedal How can i connect directly in my computer?
I was trying but is difficult please help me whit some information about this connection.
THANKS
Henry.
#14 askdpfor
askdpfor
  • 2 posts
Posted 02 October 2015 - 12:17 AM
I have a line 6 hd 500x and recently I tried to connect my guitar through it to amplitube 3.but the problem is if I bypass my hd500x still in monitor I am getting the clean guitar along with the effects of amplitube 3.
Signal chain is:
Guitar > line 6 hd 500x ( bypass)> computer through USB> amplitube 3> hd500x> monitors..
Please suggest what is the problem and if I can use the line 6 hd500x as the interface without getting the clean tone on my monitors..
#15 askdpfor
askdpfor
  • 2 posts
Posted 02 October 2015 - 09:57 AM
Thanks a lot for helping me out..
  • 1
#16 cycos
cycos
  • 1 posts
Posted 31 December 2015 - 07:17 AM
Hello everyone, I just bought the pod hd500x and I was wondering if you can download sounds already made
Thanks for your help
#17 Matt_Brown
Matt_Brown
    Iknowathingortwo
  • PipPip
  • 246 posts
Posted 01 January 2016 - 12:37 AM
Head over to customtone. It's the Line6 database for such things.
#18 fobsternd
fobsternd
  • 29 posts
Posted 02 January 2016 - 01:18 AM
I wouldn't run the pod through a combo amp because the amp's EQ settings will affect your tones. I mean, if you're using the pod strictly for its stompbox FX then it's totally ok to run it via a combo amp.
Also tagged with one or more of these keywords: pod hd500x
