Please Help! No Magnetic Pickup Output, Variax Output Works Fine.
3 replies to this topic
#1 mohospedapetalon
mohospedapetalon
  • 1 posts
  • Registered Products:1
Posted 13 February 2014 - 12:57 AM
I have just recieved my JTV-59, an ebay purchase and I love it. But no output from the magnetic pickups. I have tried changing cables, but the fact that I engage the variax and i works is a little unsettling. I opened her up  but cant see anything loose ect and got kinda scared b the amount of cables.
Any thoughts???
Thanks in advance.
#2 Charlie_Watt
Charlie_Watt
    Power User
  • PipPipPipPip
  • 2498 posts
  • Registered Products:6
Posted 13 February 2014 - 06:06 AM
The Mags go through a relay and they should work with no battery in the JTV.  You should be able to trace it and fix it.
  • 1
#3 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 13 February 2014 - 09:23 AM
Connect ur JTV 1/4" output 2 ur amp 1/4" input.
Open up JTV + amp volume.
Shut down modelling.
Now if you strum the guitar u should hear "her"  thru ur amp.
If not, check the cable.
#4 jayson2
jayson2
    Iknowathingortwo
  • PipPip
  • 125 posts
  • Registered Products:7
Posted 13 February 2014 - 04:44 PM
Are you using a VDI cable into a HD500? If so, it could be that input selection for the HD500 patch you are using is set to the the Variax models only.
Cheers,
jayson
  • 1
