mjc02865 Posted February 16, 2014 Share Posted February 16, 2014 Is there an easy way to make all my tones relatively close to each other in loudness? The only way I know of is to choose my softest tone of the bunch--which in my case is an Acoustic Guitar sim that I created--making sure it's set as loud as possible and then adjusting the levels of all my other tones individually to match the softest one. So, this is one way... But is there another, easier way? Also, is there any downside to doing things the way I described above? Quote Link to comment Share on other sites More sharing options...
archtopeddy Posted February 16, 2014 Share Posted February 16, 2014 OPERATING TIP: The way you described leveling the tones is pretty much what I do. Unfortunately, the softest tone is sometimes way lower in volume than the loudest or even "average" volume levels of the other tones. In this case, there are two things I do to increase the volume: First, I go to the "Editor" screen and check the volume of the "Amp". If it is set less than 100 %, I increase it as appropriate. Second, I go to the compressor (Comp), turn it on if it's off and increase or adjust the Gain as necessary. This can alter your sound a bit and sometimes generates noise, so it needs to be used judiciously, but it can really help bring up some of the low volume tones. I agree with you that if there's an easier way, I'd sure like to know. If anyone has any other ideas, please share! AE Quote Link to comment Share on other sites More sharing options...
