bgeyedoc Posted February 17, 2014 Share Posted February 17, 2014 I can shift presets around easily from one location to another in a setlist, but just cant find a way to move a preset from its present setlist to a new set list. Can some one give me a step by step ? Is this even possible. Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 17, 2014 Share Posted February 17, 2014 The easiest way is to use HD500 Edit; just drag and drop from the Setlist view. You can also use the device itself. It's part of the SAVE operation; you choose the destination, including Setlist, between the two presses of the Save button. Quote Link to comment Share on other sites More sharing options...
bgeyedoc Posted February 17, 2014 Author Share Posted February 17, 2014 So if I understand this , I chose the preset I want to move, click save, then chose the destination(is that under move?) , click save the second time Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 17, 2014 Share Posted February 17, 2014 Correct. But it's not under the Move button. It's part of the Save process, between the two presses of the Save button. You use the little black knobs and maybe the nav keys to select the destination and rename the new preset if desired. It should be pretty clear when you try it out. Quote Link to comment Share on other sites More sharing options...
bgeyedoc Posted February 17, 2014 Author Share Posted February 17, 2014 Thanks I'll try tonight Quote Link to comment Share on other sites More sharing options...
bgeyedoc Posted February 18, 2014 Author Share Posted February 18, 2014 nope still cant get it from the board . In edit I got it . I am just worried on site I wont have my laptop. and I might need to move a preset from one list to another. I am apparently not to bright because I have hit every combo but cant get this to work Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted February 19, 2014 Share Posted February 19, 2014 nope still cant get it from the board . In edit I got it . I am just worried on site I wont have my laptop. and I might need to move a preset from one list to another. I am apparently not to bright because I have hit every combo but cant get this to work Load up the patch you want to move, then press SAVE once. The next screen that comes up will have destination choices. The first of the 4 small knobs below the screen allows you to choose which bank(set list)it will be saved to, and the second knob selects the patch number...1A, 1B, etc. Then press SAVE a second time, and you're done. 1 Quote Link to comment Share on other sites More sharing options...
