Help A Newbie... I Am A Technical Failure! Spider Valve 112 Mk1
spider valve mk1 112 combo
4 replies to this topic
#1 bigmanyan
bigmanyan
  • 1 posts
Posted 19 February 2014 - 01:42 AM
Help!...Please.
I used to use Marshall until i bought a Spider II 75 head, I promoted that to a spider III 150 combo, then to a HD100 ... I now have a Spider Valve 112 combo MK1 that has served me well until now!!
My volume started to drop randomly on channels, it would return simply by switching to another channel and then back again. This lead me to believe that I had a software issue... insted of performing a factory re set i did this..
1) I held tap and powered on.
2) I messed around with the dials, the channel lights for A,B,C,D, Effects and TAP switch on and off as i mess with the dials l, the lcd display went up and down as i mess with the dials.
3) I switched the amp off.
4) I switched it on again
5) The amp no longer allows me to select any amp models.
6) Hold 'A' and power up, factory re-set..
7) Still the same issue cannot select any amp models..
Oh Lord WHAT HAVE I DONE... THIS IS MY GIG AMP AAARGH, HELP AN IDIOT PLEASE!!!
#2 The_Earthling
The_Earthling
  • 3 posts
  • Registered Products:1
Posted 06 March 2014 - 11:50 AM
If you've done a factory reset and the problem hasn't gone away, you might actually have a problem with your amp. I had one strange little glitch with my Mk IV once where I lost control of the presets. There was a dead spot on one of the pots (can't remember which one). At the suggestion of Line 6 technical support I tweaked the dials and the problem went away.
#3 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 06 March 2014 - 01:13 PM
try reflashing the firmware
I'M SO HAPPY!
#4 tscoolberth
tscoolberth
  • 65 posts
Posted 16 March 2014 - 08:31 AM
How'd it turn out ?
My MK1 still going strong ... if Ifigure .. it is dies I can probably seel the Strymon preamp and Celestion Vintage 30 speaker for good money or use the chasis to build my own freaking amp.
JTV-89, Ibanez 7421, ESP-LTD Hex-7, Schecter V-1, Legator Helios, Jackson KVXMG,
Laney IRT Studio head, Randall RD45
#5 Hollatchaboy72
Hollatchaboy72
  • 22 posts
  • Registered Products:3
Posted 02 November 2014 - 05:46 AM
Hey tscoolberth,
If u ever decide to sell the strymon svpre let me know! I'm extremely interested in it!
