Matyrker Posted February 19, 2014 Share Posted February 19, 2014 As it say. I want to record with my POD HD Pro Direct out but I keep getting extra buzz. It says in the manual that if you are going out from 'balanced out' then have the switch to "lift" to eliminate any buzz. I have been switching it back and forth and have noticed no difference. I was going to record dry guitars but there is no way to reamp it with the hd pro afterwards (as far as I know.) Anyways, I must be doing something wrong. Anyone that could help would be much appreciated! M Quote Link to comment Share on other sites More sharing options...
malnack Posted February 19, 2014 Share Posted February 19, 2014 So you're taking the XLR out into an audio interface? When you say buzz, is it constant like a ground loop issue or is it occasional? I'm sure someone here will be able to help. Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 19, 2014 Share Posted February 19, 2014 Please describe your setup. Are you using the Pod HD as the audio interface via USB, or are you connecting its analog outputs to a different audio interface? What recording program are you using? Quote Link to comment Share on other sites More sharing options...
Matyrker Posted February 19, 2014 Author Share Posted February 19, 2014 It is a constant buzz. I was running XLR out of the balanced. I just tried running a 1/4" through the unbalanced out and it sounds better but there is still a slight buzz and it dumbs down my tone somehow. I am really at a loss here. Setup: POD HD Pro>Saffire 6>Mac Pro>Logic. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted February 19, 2014 Share Posted February 19, 2014 If you are using the XLR out for recording, I would not plug in the USB cable. Quote Link to comment Share on other sites More sharing options...
Matyrker Posted February 19, 2014 Author Share Posted February 19, 2014 If you are using the XLR out for recording, I would not plug in the USB cable. It is not plugged in. I'm plugged in through the saffire. Quote Link to comment Share on other sites More sharing options...
Matyrker Posted February 22, 2014 Author Share Posted February 22, 2014 Maybe a different interface? Can't see why that would make a difference? Quote Link to comment Share on other sites More sharing options...
