Variax Ghost Notes In Alternate Tunings With Newest Workbench.
variax alt tunings workbench
57 replies to this topic
#41 parismatt
parismatt
  • 3 posts
  • Registered Products:4
Posted 19 October 2014 - 12:56 PM
I posted a comment yesterday, absolutely convinced that it was a software problem and not the acoustic sound of the guitar I was hearing.
I've since listened on some proper headphones and am not so sure... a rehearsal this week will hopefully make this clearer.
My JTV-59 is so much louder acoustically than my old 700 and I'm beginning to believe this may really be the source!
#42 rabiddiabetic
rabiddiabetic
  • 13 posts
  • Registered Products:2
Posted 21 February 2015 - 02:16 PM
My Variax 600 is now absolutely useless for alt tunings.  It would be nice if L6 would chime in other then saying bring it to a service center.  My alt tunings have worked for years and I just recently made some changes in Workbench (updated version on win7 machine) and poof it's all messed up. Even if I drop just the low E to D, all the other strings are playing two notes. Sabotage?  To bad because this thing sounds great with the  Ghost saddles I put on a few years ago.  Hopefully help is on it's way?
#43 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 21 February 2015 - 02:29 PM
There is no NEW workbench for the 600.
#44 rabiddiabetic
rabiddiabetic
  • 13 posts
Posted 21 February 2015 - 03:27 PM
I was previously using version 1.58 or something like that on an XP machine .  So not sure if 1.75 on win7 had anything to do with it?  just going through what was done differently then before.
#45 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 21 February 2015 - 07:07 PM
1.75 has been out for years.
#46 rabiddiabetic
rabiddiabetic
  • 13 posts
Posted 21 February 2015 - 07:57 PM
Thanks for steering me in the right direction Charlie. Ground wires on two of the saddles found their way loose.  All is good.  Sorry L6 I need a Snickers.
#47 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 22 February 2015 - 06:27 AM
Glad you solved it.  I had grounding problems on my 500 with the original piezos.  I also upgraded to the Ghost saddles.  It was difficult to connect all of the ground wires but the results were worth the effort.  No more grounding problems.  I wish that Line6 would do that on the newer Variax designs.  It's still the single wire relying on the case for ground.  This works for a while but it's easy to have a bad ground which causes all sorts of problems like the one you had.
  • 2
#48 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1964 posts
  • Registered Products:3
Posted 22 February 2015 - 11:02 PM
You could solder the ground wires to 1 wire then lead it to the place where the ground is.
I agree about using the case again for ground. Bad design which will ultimately cause grime and oil to disconnect the ground when enough gets in there.
For a minute there, I lost myself.
#49 rabiddiabetic
rabiddiabetic
  • 13 posts
Posted 26 February 2015 - 03:51 PM
 That's exactly what I did when I fixed the problem, much easier then getting all the ghost saddle ground wires to ground point.
  • 1
#50 collingtech
collingtech
  • 4 posts
Posted 10 April 2015 - 04:36 PM
hey guys where i get the 3.00 flash memory firmware?
thanks
#51 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17813 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 10 April 2015 - 05:28 PM
first you build a delorean.... then you find 1.2 jiggawatts.... mash the gas and hit 88mph.
 if i had to field a guess for 3.0, you might try 2017
thanks
#52 collingtech
collingtech
  • 4 posts
Posted 11 April 2015 - 08:37 AM
well thats demoting , actually my variax had bricked so im evaluating options , i could do a reflash , i had the tools but the .vxf apears to be proprietary from line 6 i cannot open in my flash programer , i need a hex file format or similar , pretty lollipop situation actually, guess start looking for a reflah service in some line6 service center (will cost an arm?) after searching for a new board whit no sucess what more i can do?? yep the delorean thing wont work , the flux capacitor is broken actually
#53 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17813 posts
Posted 11 April 2015 - 08:49 AM
sorry dude i was trying to be funny and thought this was the pod group where 2.6 just came out.
what variax do you have?
#54 collingtech
collingtech
  • 4 posts
Posted 11 April 2015 - 09:13 AM
variax 700
#55 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17813 posts
Posted 11 April 2015 - 10:10 AM
have you tried doing the flash from another computer?
#56 collingtech
collingtech
  • 4 posts
Posted 11 April 2015 - 10:48 AM
yep (3 separate computers same result) , after 20 minutes a error display when triyng to update( error code 8000900C MIDI device timed out) , as i read in forums, i just brick the thing
(http://line6.com/sup...w/thread/86238/) same beatyfull history
#57 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17813 posts
Posted 11 April 2015 - 11:16 AM
i'd suggest opening a support ticket, and maybe calling them (M-F 9-5PST) they can probably walk you through some options.
http://line6.com/company/contact/
#58 Segomil
Segomil
  • 45 posts
  • LocationMorin Height
Posted 19 October 2015 - 08:37 AM
It's the same for My variax JTV69 & much more ... https://www.youtube....h?v=RDJFAqsnueo
Also tagged with one or more of these keywords: variax, alt tunings, workbench
