RNRage Posted February 23, 2014 Share Posted February 23, 2014 4 Ohm minimum impedance when running a cabinet into both speaker outputs?? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted February 23, 2014 Share Posted February 23, 2014 Don't think I've ever had an amp with anything less than a 4 ohm minimum load. 8 ohms seems to be more common, but i've seen 4. I'm guessing you've got a single cab wired in stereo with two ins? Quote Link to comment Share on other sites More sharing options...
RNRage Posted February 24, 2014 Author Share Posted February 24, 2014 Nah. I have 2 cabs.. Both have a 12 and 2x8's. One reads out 10.21 ohms on the meter.. The other, 8 ohms even. Run in parallel, that's roughly 4.5 ohms.. Which should be safe to run.. I'm just checking here first, lol. Attached a pic of the 2 cabs. . They're between the Mesa and Marshall 4x12 cabs. Don't think I've ever had an amp with anything less than a 4 ohm minimum load. 8 ohms seems to be more common, but i've seen 4. I'm guessing you've got a single cab wired in stereo with two ins? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted February 24, 2014 Share Posted February 24, 2014 Nah. I have 2 cabs.. Both have a 12 and 2x8's. One reads out 10.21 ohms on the meter.. The other, 8 ohms even. Run in parallel, that's roughly 4.5 ohms.. Which should be safe to run.. I'm just checking here first, lol. Attached a pic of the 2 cabs. . They're between the Mesa and Marshall 4x12 cabs. Wow...that looks like a fun room! I got a Mesa 2x12 cab I'm getting rid of...seems to be the only thing you ain't got, you want it, lol? Quote Link to comment Share on other sites More sharing options...
RNRage Posted February 24, 2014 Author Share Posted February 24, 2014 It's a very heavy room.. Especially for my bad back, lol. I just sold the Triple Rectifier and the Marshall 2x12 cab not too long ago. The blue Jackson and the black Epiphone LP are gone, as well. Bought myself quite a bit of goodies to replace them, though. The Marshall head and Mesa 4x12 cab are the next 2 pieces to hit the road. I have an old Yamaha 2x12 combo and a 2x12 cab that aren't in that picture.. They don't fit in the room. I have 2 bigger keyboard amps that aren't in that picture either. As well as a 3 space rack with an old Behringer V-Amp Pro. All 5 of those things are getting incorporated into my setup. The keyboard amps for the V-Amp.. The 2x12 for my Fender tube head I have sitting there.. The Yamaha combo because the thing is absolutely fantastic for Jazz cleans.. I'm just going to need a head to push those 2 oddball cabs that I have. That Marshall 4x12 is getting the front bezel pulled out of it and I'm installing a shelf into it.. It'll act as a shelf for my Fender head and inside, will house my pedals that I'm not using. I can always put the front bezel back on then, if I ever wanted to use it. Wow...that looks like a fun room! I got a Mesa 2x12 cab I'm getting rid of...seems to be the only thing you ain't got, you want it, lol? Quote Link to comment Share on other sites More sharing options...
