Changing The Wiring On My Jtv-89
tyler variax wiring jtv-89 switch pickups
4 replies to this topic
#1 Inerzia
Inerzia
    Iknowathingortwo
  • PipPip
  • 369 posts
  • LocationSpain
  • Registered Products:7
Posted 23 February 2014 - 07:53 PM
I've been scratching my head for some time now trying to work out how the pickup switching works in my JTV-89,
mainly because, although I like the pickups, I wanted to have more options on the magnetic side.
I wanted something like what I would want on a HSH strat.
That is: two 4conductor humbuckers with duncan triple shots and a single coil sized humbucker in the middle.
The switch, as it is, doesn't give any option to add another pickup, because all four (well, five) conductors are
soldered on a small PCB that's attached to the selector and it's impossible to see inside the selector to find
some way to add anything or change any of the pickup/coil settings, so... I went and opened it.
Well, I didn't exactly open the one inside my guitar, but a spare I got from the spanish distributor.
The switch was failing and I didn't want to send the JTV to tech service because they are sluggish, so I asked them
for a replacement switch and they sent it, on the condition that the guitar would be serviced at the store where
I bought it. In fact, they did send the wrong switch the first time, so I ended up with two, one that seems to belong
to a JTV-69 and the one I needed.
I've been a customer for a long time, so the people at the store agreed to let me change it myself, which I never did,
because once I bought a hardcase for the guitar, the switch stopped failing so often (It almost never fails now and
I've worked out a way to quickly get it back to normal).
So I opened the selector and found out how it works.
It works in the same way a superswitch would, only this one is preset. There are fixed contacts and mobile ones.
The fixed ones are printed in a way that does the coil splitting in positions 2 and 4 and does, well... you know...
what a JTV-89 does with its mags :-)
The switch is some kind of 2P5T, where on one pole you select the magnetic pickup setting and on the other
you select modeling pickup setting. On the modeling side, the contacts are arranged in a standard fashion.
Bad news first:
The modeling side of the switch has three resistors (18,65k, 75,1k and 37,2k are the exact values, though
they most likely correspond to standard values of 18k, 75k and 36k) and I'm guessing the variax brain detects
which position the selector is on based on the resistance measured between the two contacts that go out the PCB.
Good news: The values of those resistors are standard and they are possible to replicate, so you can use a
standard two pole five throw blade selector and add another pickup (or whatever you want to do with your five)
Better news: The lower PCB can be desoldered from the selector and soldered to a different one, so you don't
have to mess around with resistor values and provide some new small board to solder them onto.
PICTURES:
YES!! I know I should include pictures in this very post, and at this very moment, but my camera is out of battery
and my phone isn't good enough, so you'll have to wait, but the pics will come.
I won't actually modify the guitar until the triple shots and the duckbucker are here, then I will have a friend route
the guitar for me and then I will do the electronics so, for now, the only pics I'll post are the ones of the selectors.
In a month or two (when I can buy the stuff) I'll start doing the mods
  • 2
#2 Inerzia
Inerzia
    Iknowathingortwo
  • PipPip
  • 369 posts
  • LocationSpain
Posted 24 February 2014 - 11:34 AM
Here are the pictures of the JTV-89 selector
Attached File  Switch-JTV89.jpg   213.99KB   33 downloads
And what I guess must be a JTV-69 selector
Attached File  Switch-JTV69.jpg   94.38KB   18 downloads
  • 1
#3 Inerzia
Inerzia
    Iknowathingortwo
  • PipPip
  • 369 posts
  • LocationSpain
Posted 24 February 2014 - 11:50 AM
That's the other part of the switch, the cover and the rotating shaft and contacts.
Attached File  Switch-ShaftAndContacts.jpg   104.17KB   15 downloads
Both switches closed
Attached File  Switches-JTV.jpg   119.3KB   18 downloads
  • 1
#4 xavierb
xavierb
    Iknowathingortwo
  • PipPip
  • 104 posts
  • LocationBrisbane
  • Registered Products:4
Posted 27 August 2015 - 04:35 PM
Do you have any update on this project? Did it work in the end?
I would very much like to find wire my JTV89 like Ibanez does, i.e., position 2 = neck pickup in parallel and position 4 = bridge & neck single in series.
Do you (or does anyone) know if that's possible without using a custom made PCB for the switch?
#5 Inerzia
Inerzia
    Iknowathingortwo
  • PipPip
  • 369 posts
  • LocationSpain
Posted 24 September 2015 - 05:58 PM
Hi Xavier!
I do have news, the project has been succesfully finished!
Everything has worked out as expected.
There is, though, something I don't like: On both stock pickups, the south coils sound noticeably weaker than their northern companions, so I might end up replacing them for two duncans.
In the middle position, I went for a Little '59 instead of the Duckbucker, and I wired it with a DPDT switch for series/south/parallel.
I also added an on/off switch to be able to add the neck pickup to whatever position I'm in, so I can use it with the bridge pickup or use the three at once.
The bridge had to be replaced too, because the piezo saddles of the first and second strings were pierced (by the action of the strings themselves).
I put a GraphTech Ghost wraparound bridge, which required some wood work for the new studs, but works better than the old one. Better signal and less artifacts.
Pictures are coming
Also tagged with one or more of these keywords: tyler variax, wiring, jtv-89, switch, pickups
